Like Tree2Likes
Tamiya TA05MS
Old 10-11-2007, 04:18 AM
  #751
nikkiesteban's Avatar
Originally Posted by Xanavi_R34 View Post
don't use the stock suspension setup... It is very low, as in too low... And yeah, the front is really higher than the rear if you're going to put it on stock manual setup... Always make your starting setup (or point) to 5.5mm rear and 5mm in front... Like what sir al said...
ok thanks. Our average ride height here in paved cement (front 7mm and 7.5mm rear).. maybe i will try 5.5. but i might scrape my chassis..
I also want to ask if I will set my ride height like 7 to 8mm should I also adjust the stabilzer(the adjusters of stabilizers)?
nikkiesteban is offline
Old 10-11-2007, 02:05 PM
  #752
Does anyone have a pdf version of the MS manual they could send me or link me to?
DOTMAN is offline
Old 10-11-2007, 04:22 PM
  #753
HI_808's Avatar
Here you go DOTMAN:
http://www.tamiya.com/japan/download...ual/ta05ms.pdf
HI_808 is offline
Old 10-11-2007, 04:27 PM
  #754
Man, you gotta love the internet
Thanks, Hi...you da man!!
DOTMAN is offline
Old 10-11-2007, 04:36 PM
  #755
Trader Rating: 32 (100%+)
Originally Posted by HI_808 View Post
Why you helping the competition, man!?
ittjv is offline
Old 10-11-2007, 04:47 PM
  #756
I want to ask if I will set my ride height like 7 to 8mm should I also adjust the stabilizer(the adjusters of stabilizers connected to arm)?
Old 10-11-2007, 05:15 PM
  #757
HI_808's Avatar
Your competition, not mine's .
I just hope all you guys win since actually racing my TA05MS has become out of the question due to time conflicts with the local races.
HI_808 is offline
Old 10-11-2007, 05:17 PM
  #758
HI_808's Avatar
nikkie,
I don't think you have to adjust the stabilizers if changing the ride height. You can if you want to, but the difference should be negligible. Just make sure you change your droop settings to accommodate for the height adjustment.
HI_808 is offline
Old 10-11-2007, 05:46 PM
  #759
nikkie,
i see. thanks.
Old 10-11-2007, 11:52 PM
  #760
Hebiki's Avatar
Trader Rating: 26 (100%+)
thats right.. you gotta through to oliver to get to me
showdowns of the TA05MSs this sat!
jose.. do u have any extra belts by chance?
Hebiki is offline
Old 10-12-2007, 12:08 AM
  #761
Hebiki's Avatar
Originally Posted by CarKing View Post
What are the benefits of the Delrin style outdrives?
andrew.. VERY important PM.. please let me know asap. thanks man!
Hebiki is offline
Old 10-12-2007, 03:31 AM
  #762
Xanavi_R34's Avatar
is your track that you're running on smooth or rough??? If it is smooth, you should not have problem with 5 and 5.5mm ride height but if not, then you should not do 5 and 5.5mm ride height unless you have a tub tape under the chassis... Which I doubt you have it on under...? for you have said that you will scrape your chassis... (under)...
But also remember that making your ride height high will make handling terrible in corners, also going to low will make it hard to turn in tight turns... So better play with your ride height, etc... stabilizers do less in setting up the car, so I think you don't have to... but I would suggest you to try loosening the screws in front (the one which holds the stabs, not the stopper) then tighten the one in the rear (same goes here, not the stopper)...
And also don't forget your droop... This does alot in setups...
Please take note of what have said in this message, this is based in my personal opinion, experience, etc... Thanks...
P.S., ei bro, could you do me a favor? Please tell Dennis Ventura that I am very sorry not replying to his texts because I do not have load yet, maybe if I have load, I will reply back... Thanks...
Xanavi_R34 is offline
Old 10-12-2007, 04:16 AM
  #763
ok. thanks for some tips. I will try all the possible setup in the cement track.
I will tell dennis tommorow. thanks
Old 10-12-2007, 08:38 AM
  #764
AWK
AWK's Avatar
Hey bud, if only we were still in the old building it wouldn't be a problem, but due to the lame new location, its tough. Check your PM
AWK is offline
Old 10-12-2007, 09:08 AM
  #765
Hebiki's Avatar
thanks man. its the thought that counts. ill take you up on your offer though.
btw.. you ever gonna join us for some racing? it'd be nice to see 4 TA05MS on the track.
Hebiki is offline
