Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-15-2013, 10:01 AM
  #18586
Default Tamiya Pre mount tire HELP
Hi guys,
What are the difference between 60D Type A premounts and the 60D S grip premounts?
fx35rc is offline
Old 03-15-2013, 01:15 PM
  #18587
Originally Posted by fx35rc
Hi guys,
Type A are slicks, S grip are Radials.
jha07 is offline
Old 03-15-2013, 01:26 PM
  #18588
Thanks..much appreciated
fx35rc is offline
Old 03-16-2013, 09:18 AM
  #18589
Trader Rating: 72 (100%+)
Do the TCS rules for the Mini class require use of only Tamiya shock springs or are any manufacturer's shock springs legal?
Wondering because I can't quite tell from the rules' verbiage.
waswadener is offline
Old 03-16-2013, 09:34 AM
  #18590
MD
MD's Avatar
Trader Rating: 136 (100%+)
TCS Rules:
All Tamiya vehicles must use Tamiya parts only. No parts from other manufactures unless specified within this document.
MD is offline
Old 03-16-2013, 09:42 AM
  #18591
So, Tamiya springs only. Check and thank you.
Old 03-16-2013, 10:29 AM
  #18592
MD
MD's Avatar
You can check the rules, but I am pretty sure you have ti use Tamiya shocks and springs.
MD is offline
Old 03-16-2013, 10:30 AM
  #18593
Guys, look at this
Tamiya Steel Gear Differential Unit Rear TA06 TA06 PRO FF-03R XV-01 #54471
It's from the XV-01 chassis, reckon they fit into the m05? Visually I'd say yes
cheapskate.brok is offline
Old 03-16-2013, 10:39 AM
  #18594
monkeyracing's Avatar
Does the XV01 use a 39 tooth differential with the same pitch as the M chassis?
monkeyracing is offline
Old 03-16-2013, 10:49 AM
  #18595
Oh look, would this be an alternative too?
3Racing Gear Differential 39T For 3racing Sakura FF(#SAK-F01)
Old 03-16-2013, 12:31 PM
  #18596
fresnojay's Avatar
Nevermind
Jason
fresnojay is offline
Old 03-18-2013, 01:38 PM
  #18597
Okay, wrong place, but...who knows anything about the ABC Genetic and basic setup for it? Drop me a PM.
Old 03-18-2013, 03:19 PM
  #18598
Originally Posted by cheapskate.brok
Guys, look at this
That's a standard TA06 gear diff (in black rather than white) with steel internal gears included which used to be an option (#54428). The casing is certainly not steel...
Edit: I looked at that picture again and there are two different assembled diffs... one does look like it could be even made out of steel but that would be madness, what's going on in the pic?
Well the TA06 (and TRF511 w/Upgrade Kit that I'm running) both use the same diff and yes, it's 39t. Whether it's compatible with the M chassis I wouldn't know (it's pretty big!).
djmcnz is offline
Old 03-18-2013, 07:14 PM
  #18599
i read somewhere in the Australian forum that the Sakura FF diffs indeed fits in the m05 (with a little mod with no futher details). Nways, I am getting one just for curiosity's sake. Let you guys know in 2 weeks
Old 03-18-2013, 08:54 PM
  #18600
I)arkness's Avatar
if you are looking for a oil filled gear diff for the m05 cant go past the TOP Sabre FD #PO-SDT114 gear mesh is same as tamiya, and no mods need to be done, expect a few more shims on the outdrives to center it in the chassis
I)arkness is offline
