Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-11-2005, 03:22 PM
  #9901
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by tony rivas
hey jon 58? losi have 60,57,56,55,54 unless 58's are new?
I'm sorry, they're the 57. Not sure what I was thinking. I have drilled them out to the 56 size but didn't really notice an improvement that was worth the work.
Jon Kerr is offline
Old 06-11-2005, 03:25 PM
  #9902
P-DUB's Avatar
Did you take out the drilled ones and go back to the stock 3 hole If not..You should
P-DUB is offline
Old 06-11-2005, 03:43 PM
  #9903
Paul, is it from the RDX??
MattW is offline
Old 06-11-2005, 03:55 PM
  #9904
P-DUB's Avatar
Yes...It didn't seem to really improve steering (not yet ), but did make the car way more consistent. No more trim issues or oversteer (centering up on exit).
P-DUB is offline
Old 06-11-2005, 04:18 PM
  #9905
STLNLST's Avatar
Trader Rating: 32 (100%+)
After three rounds of qualifying my oneway set up is sitting 4th in 19 turn. TQ is 24 5:06 second in 24 5:08. something 3rd is 24 5:08.something (Barry Baker) me 24 5:08.something. It's real close from 1st to 4th. I didn't get a hold of the Schumacher blue inserts for the RP 36's to test but a local racer did have the yokomo firm super thins so I glued them up. The car was stuck. It flowed really well and had nice bite. Once the track started to heat up some they were a little on the edge. I plan on trying the same insert in a set of RP 40's. Barry made fun of me running your body colors but it will be in front of him once it's all said and done. Time to go to the movies so I'll report more later on.
STLNLST is offline
Old 06-11-2005, 05:14 PM
  #9906
P-DUB's Avatar
That sounds awesome Clint, keep up the good work! How's your more rounded white brother doing....
P-DUB is offline
Old 06-11-2005, 05:19 PM
  #9907
P-DUB's Avatar
Nevermind...Found the results! http://www.speedworldraceway.com/Rac...05.txt&ID=1840
P-DUB is offline
Old 06-11-2005, 05:39 PM
  #9908
Jon Kerr's Avatar
Yes I did
Jon Kerr is offline
Old 06-11-2005, 05:40 PM
  #9909
Jon Kerr's Avatar
Oh no, I may need to make an apology Nah! Never happen
Jon Kerr is offline
Old 06-11-2005, 05:50 PM
  #9910
Tony Rivas's Avatar
Trader Rating: 56 (100%+)
cool thanks
Tony Rivas is offline
Old 06-11-2005, 10:14 PM
  #9911
STLNLST's Avatar
Thanks PW. With qualifying only taking the best of the four rounds the rocket round will be the last qualifier tomorrow morning so I hope to put a great run in to improve on the time from today. I have tire and insert tested every round. The best combo i like so far has been the Sorex 36 with Xenon blue inserts once it starts to get hot. The track temp got up to 140 today. In the 110 range the RP 36 with the yok firm was dialed. I may use it for qualifying tomorrow when the track is rather cool. My last qualifier I ran Sorex 36 with Schumacher blue inserts (already had these mounted up) Tomorrow is sure to be fun. I'll update ya once I get back home sometime in the late evening.
STLNLST is offline
  #9912
STLNLST's Avatar
You and i both know that DADDY was right...
STLNLST is offline
Old 06-12-2005, 04:46 AM
  #9913
Ok. MI3 at the end of the year, maybe. You know, for a Schumacher car that's an awfully long product cycle.
Will there be interrim edition of the MI2 with the new shcumacher shocks I've heard rumours about and with the Teemu chassis? Or will that be the MI3?
I'm thinking about buying MI2. But I have Axis in a box somewhere, it's IMO pile of It must be the worst designed car I've ever had, even with the typical Schumacer good points like the blades on the driveshafts. The only things I could rely on on that car is that it would become tweaked in every single heat, that it would get rocks in the belts and maybe snap one and that the front bumper would break at least once every race day. After my experience with that car I swore never to buy Schumacher car again. But maybe I'm gettin mellow with old age. Still if I have to buy TRF shocks and BMI or Teemu chassis and maybe Corally steering rack to get MI2 to work on track, then why do it?
andsetinn is offline
Old 06-12-2005, 05:54 AM
  #9914
STLNLST's Avatar
No one seems to remember us posting that MO was running a box stock car in modified for a while and doing very well with it. The BMI chassis Teemu, are just upgrades. These item aren't needed in order to get the car to work. The Tamiya shocks are just easier to build which equals to a hassle free build time after time. The only thing that I feel is needed are the lowered carpet towers. Instead of coming on here and flaming the old car with your past experiences try coming on here asking the question you have about the new car that you might be looking into getting. Getting off on the wrong foot isn't going to help point you in the right direction. The new car doesn't tweak too easily so that problem is now gone. The bumper holds up pretty well in stock form. The only thing that we have done to reinforce the front bumper is to get the Pdub front bumper foam. It's firmer than the stock foam. Everyone on here will be more than happy to answer any questions that you have. We're here to help. Are there any other issues that concern you at this time????
STLNLST is offline
Old 06-12-2005, 05:58 AM
  #9915
Matt Howard's Avatar
TOASTY!
Matt Howard is offline
