Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-23-2019, 05:04 AM
  #29866
Originally Posted by Tim K
Originally it came out with a lightweight/carbon reinforced TL01 chassis, then Tamiya released it with the M03R kit.
The bumper plate came also in the TL01B Baja Champ and Baja King buggies and the TL01LA on road kits. Fibrelyte in the UK do a nice carbon version. Also, the l/w TL01 chassis was DEFINATELY lacking any carbon reinforcement (sadly), just thinner ABS plastic - so many were lost to minor impacts when racing.
Mini35 is offline
Old 10-24-2019, 11:16 AM
  #29867
monkeyracing's Avatar
Now I see it, I’ve actually had a few of those. Not sure where they went. Dang.
monkeyracing is offline
Old 10-28-2019, 05:56 PM
  #29868
M04 swaybars? I’m proud of those.
I’m slapping an 03 right now and I can’t remember which end got the hard springs. A 2 year break from mini has really dulled my instinct.
Found some DCJs with 30mm shafts tonight. These might fit the M03! Removed my cheater gear. (Machined Delrin!)
Old 10-30-2019, 04:21 AM
  #29869
Tim K's Avatar
My old M03 set up was fluro red springs front (soft), grey or purple springs rear (super hard/ultra hard) ... and hard rear sway bar, no front bar.
That was for tarmac, not sure if it will work for indoor carpet.
Tim K is offline
Old 10-30-2019, 05:35 PM
  #29870
I remember running that setup on your recommendation. I found it didn’t matter if a sway bar was used or not. The carpet is probably very grooved in, so that might change. I’m set up with short reds and blues right now. Will switch to short extra hard whites of needed and greys from there.
i have to remember how to drive the thing again first.
Old 11-01-2019, 04:14 PM
  #29871
nikkiesteban's Avatar
Default m05 shorty battery pack
Guys I'm thinking installing a shorty battery pack in my m05 vii, I have the lightweight aluminum holder (using tape to hold the battery).
Do you have one installed? care to share pics and some wirings?
nikkiesteban is offline
Old 11-01-2019, 11:34 PM
  #29872
damang999's Avatar
Trader Rating: 15 (100%+)
I ran shorty in mine. Pretty much the same as a full size pack but I only taped one side of the battery opposite to the terminals and shortened the wires as needed
damang999 is offline
Old 11-02-2019, 12:58 AM
  #29873
Can you post a picture (if its ok)? I would like to see your setup using shorty
Old 02-03-2020, 09:36 AM
  #29874
damang999 I'm also interested in this, any update?
raytay112 is offline
Old 02-04-2020, 02:05 AM
  #29875
damang999's Avatar
sorry guys I have sold my m05 so can’t take any pics but it’s not complicated just centralize the battery tape one side opposite to the plug
Old 02-05-2020, 09:14 AM
  #29876
Got it, thanks for taking the time to respond.
Anyone here running their M05 for TCS this year??
Old 02-05-2020, 09:44 AM
  #29877
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I'm sure there will be a few running for the hell of it but it will be a massive disadvantage now that the 2020 rules allow open gearing.
gigaplex likes this.
Dan is offline
Old 02-05-2020, 11:14 AM
  #29878
underdog FTW! it would be nice to see some top 5 finished with a M05
Old 02-10-2020, 07:24 AM
  #29879
Tamiya M05 Screws:
  • M3 x 6 Flat - 4
  • M3 x 8 Flat - 1
  • M3 x 16 Flat - 1
  • M3 x 8 Button - 6
  • M3 x 10 Button - 35
  • M3 x 12 Button - 6
  • M3 x 15 Button - 14
  • M3 x 25 Button - 2
Tamiya Specific Screws:
  • M3 x 10 Step - 2
  • M3 x 14 Step - 14
  • M3 x 18 Step - 4
Nerobro is offline
Old 02-18-2020, 03:18 PM
  #29880
hobbipro's Avatar
Trader Rating: 23 (100%+)
I will be acquiring a M05 in a few days.......For those who have tried a Yeah Racing 38t sealed gear diff, is there any problems using this with stock gears? The stock open diff is 39t, so why is the YR diff one tooth short? In my mind this would be loose, not mesh well, but I don't know. I see they did make a separate 39t gear for this diff sold separately, but seems this has been discontinued. Also the SpecR, and 3 racings diffs seems to be 39t, but those are hard to source now too. Maybe just going with a TA03 ball diff is the way to go...
hobbipro is offline
