Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 12-02-2016, 05:31 PM
  #28366
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by (0000000000)
I like these ones, as they are $10 USD cheaper, which is like....$900 Canadian right now.
http://www.rcmart.com/3racing-m0533-...h=595_744_1389
Hey, do you have to use the 3mm wide bearing that comes with those, or can you squeeze in a 4mm? If it's the former, I'll have to order some 5x10x3 bearings. My steering knuckles use 10mm.
Have you seen rebuild kits for these? Getting parts will be vital in my decision making.
monkeyracing is offline
Old 12-02-2016, 05:41 PM
  #28367
gigaplex's Avatar
Originally Posted by eR1c
..strike that, Tower just changed the status to "late Jan" (from "late December").
so yeah, not counting on this one.
And before that it said late November
gigaplex is offline
Old 12-02-2016, 05:54 PM
  #28368
(0000000000)'s Avatar
Hi Jim, I haven't checked if these are the same as my Sakura TC. I will check tonight and let you know.
Other than the length of the CV shaft, these appear to be identical to to my Sakura TC's driveshafts.
Chuck
(0000000000) is offline
Old 12-02-2016, 06:42 PM
  #28369
Just got home. Without dismantling my current mo5, I'd wager that the bearings are 5x11x3. How did you get 5x10's to work on an m05?
Old 12-02-2016, 06:43 PM
  #28370
And yes, because they are identical to my Sakura SSK's, the rebuildable parts are available, and it is easy to do.
Old 12-02-2016, 07:55 PM
  #28371
Using the 54177 uprights. They use 10mm bearings. Just never used 3mm wide bearings before.
Old 12-04-2016, 01:33 AM
  #28372
Schs2013's Avatar
M05v2 I see is available hear
http://www.tqrcracing.com/shop/product_view.asp?p_id=8032
Schs2013 is offline
Old 12-04-2016, 11:04 AM
  #28373
eR1c's Avatar
I was looking for the "r" version of that kit ...which has some upgraded parts included for a better overall deal.
eR1c is offline
Old 12-04-2016, 12:26 PM
  #28374
Raman's Avatar
Trader Rating: 91 (100%+)
Part number starts with a 8 so it was a limited kit. Most likely it won't be restocked
Raman is offline
Old 12-04-2016, 03:23 PM
  #28375
Sorry Chuck, just realized I wasn't being very specific. The 54177 uprights, like the alloy rear uprights, use a 5x10x4 bearing. Stock size bearings for the plastic kit parts and the 3Racing/Yeah Racing M05/06 "bent" style uprights are 5x11x4.
Old 12-04-2016, 06:23 PM
  #28376
eR1c's Avatar
yeah, that is what it is sounding like.
well maybe ill just pick up the M05V2 ...will give it 'til after Christmas though/not in a huge hurry.
eR1c is offline
Old 12-04-2016, 07:15 PM
  #28377
gigaplex's Avatar
It was a weird release. They really should have included the aluminium steering parts (and maybe the heat sink bars too). The only way to get matching black aluminium parts was to buy the 84407 set, but then you'd end up with duplicates of half the parts. And if you wanted the black battery mounts, the only way to get that was to get the R spec chassis, so you couldn't just buy a regular M05 and upgrade it separately.
gigaplex is offline
Old 12-04-2016, 07:43 PM
  #28378
Schs2013's Avatar
Thought that it would be of help. Didn't know there was that much difference between them R version and what I linked
Schs2013 is offline
Old 12-04-2016, 08:00 PM
  #28379
gigaplex's Avatar
The main difference is aluminium threaded shocks and double cardan universals. There are also a bunch of minor upgrades including hinge pins and hex machine screws.
gigaplex is offline
Old 12-05-2016, 07:19 AM
  #28380
eR1c's Avatar
For the money the "R" was the best kit ...I never picked one up as I never thought it would have been a limited edition. Plus I have an M05 (which I've upgraded from M05, to vII to pretty much an r). But thought it would be fun to build another.
Speaking of,
has anyone driven an M06, how does it compare to the M05? I get its rear wheel, -does the rear want to spin out like an f1? I've seen some interesting vid's w/ M06's beating M05's on YouTube. I've always assumed the M05 was the better handling and performing car ...is that assumption still true?
I do think the M06 has an interesting looking design, which appears to have a lower center of gravity (than the M05)
eR1c is offline
