Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-09-2020, 07:07 AM
  #29896
dmcguire's Avatar
Trader Rating: 37 (100%+)
Originally Posted by KoE
Guys,
I've left the TC scene for quite some times now and would like to get 05 kits for my kids. Is 07 any better? Also, can anyone point to a well-stocked online seller. We've don't have access to local tamiya store anymore. Thanks.
Granted the M05 is a bargain considering you get the body and ESC/motor combo and tires, but If you can go with the 07, I would. Aside from the front steering knuckles, the M07 is real good.
The biggest thing that would steer me away from the 05 for the kiddos is that I found when they updated front chassis section to fit a square battery pack, they seemed to be weak at the front camber link location. I broke a few chassis right there with light hits. Putting JB weld inside the chassis fixed that, but still, if there will be any bashing it could be a problem. Also, dirt seems to get inside the chassis, but you can use silly putty to seal those holes.
Like mentioned TQ is a great resource for parts. Ebay as well.
dmcguire is offline
Old 06-10-2020, 12:06 AM
  #29897
KoE
KoE's Avatar
Thank you for the info!
dmcguire likes this.
KoE is offline
Old 06-14-2020, 02:38 AM
  #29898
Chris916's Avatar
Default 3 racing M06-06 Gear differential
Hello,
I stripped some gears inside 3 racing M06-06 Gear diff 39T and I'm navigating inside 3 racing spare parts to find correct references.
I found that gears set should be SAK-65F/V2, but SAK-XS110A seems identical with same applications list.
For paper gasket, yellow thickness1 mm, seems to be SAK-XS110E.
Appreciate if someone already performed the diff renew can share experience and references.
The stripped reason is not clear, it worked well for more than one month (on M-05 / 17.5t brushless / 100k oil) and yesterday, ultra hot day, ugly noise started...The 4 tiny 10t gears are stripped.
Thanks in advance.
Chris916 is offline
Old 06-14-2020, 07:40 AM
  #29899
Guys,
M-07 is better for racing if you are looking to be fighting for the win. Also m-07 is chassis only, no bodies.
M-05 is just fine for your kids. When they wear out the m-05, maybe then replace with M-07.
dman18t is offline
Old 06-15-2020, 10:10 AM
  #29900
cementsurfer86's Avatar
Originally Posted by raytay112
underdog FTW! it would be nice to see some top 5 finished with a M05
I was able to win our NW regional last year with my trusty M06, which sadly was probably the last year either a 05 or 06 would be competitive now that open gearing is allowed. I will say, it was a total blast flogging an inferior car around and beating the 07's, especially with a RWD 06, which was one of the most undesirable M-chassis cars ever. It was work though.... man.... haha.
cementsurfer86 is offline
Old 06-15-2020, 03:09 PM
  #29901
Raman's Avatar
Trader Rating: 85 (100%+)
i was hoping to do the same last year with my M06.. Sadly my campaign was unsuccessful due to the 11th hour change to the Ride 33. To obey the rules I didn’t bring my m chassis tyres and later would learn that the top drivers were running them and not the Ride 33.
She now sits on the shelf and her replacement is an M08!
Raman is offline
Old 06-17-2020, 08:35 AM
  #29902
Originally Posted by Raman
i was hoping to do the same last year with my M06.. Sadly my campaign was unsuccessful due to the 11th change to the Ride 33. To obey the rules I didn’t bring my m chassis tyres and later would learn that the top drivers were running them and not the Ride 33.
Mine as well. Finally getting around to building my '08. Love the challenge of a RWD mini.
Old 06-17-2020, 10:52 AM
  #29903
Raman's Avatar
They do really well on carpet.. especially the M08! Only thing I don’t like about it is the front upright design. Tamiya decided to use an insert for caster angle.. which makes it really brittle.
Im switching mine to the M07.. caster plate and upright for this weekends TCS.
cementsurfer86 likes this.
Raman is offline
Old 06-18-2020, 03:34 AM
  #29904
Evening all,
I recently got the hollow shafts for my m05, i use bearings in it and was wondering if i still had to use ceramic grease on them as per tamiya instructions on original kit?
Anastasios is offline
Old 06-18-2020, 05:10 AM
  #29905
DaSilva3525's Avatar
Originally Posted by Anastasios
Evening all,
In my opinion leave them dry. Usually the grease will invite dirt or crap to stick to the gears, not to mention the increased resistance caused. I have never once greased the gears and always had a good result.
DaSilva3525 is offline
Old 06-18-2020, 07:38 AM
  #29906
I'll usually use a wax-based lube for efficiency, but other than that, I don't use a "grease".
Old 06-19-2020, 06:34 AM
  #29907
Thanks for your tips guys, also what are the go to shorty lipos to use in the m05 v2?
Old 06-19-2020, 06:46 AM
  #29908
I mean, any shorty pack will do you good in the V2. If you want to get trick you can try the LCG Shorty packs but I would start with a standard 4000 pack or what not. If you want to try something you can put a piece of foam or something on top of the battery pack so in can sit on the bottom of the chassis instead of hanging in the air for more of a lcg effect.
Old 06-20-2020, 01:13 AM
  #29909
where do you guys measure the front ride height on a m05 v2 with the one piece front arms? they have a bit of plastic which ends up almost 2mm off the ground?
Old 06-20-2020, 01:37 AM
  #29910
gigaplex's Avatar
I use a drill bit and see if the car can roll over it.
gigaplex is online now
