U.S. Vintage Trans-Am Racing
#7981
[QUOTE=414MPH;6947332]
Roooobbbbbb!!!!!!!....ppl are not playing nice!!!...Im telling on all yall...wait till Rob finds out...you'll going be in so much trouble...man you wont get your toys back for a month
To carry your inaccurate synopsis a bit further...what kind of piece of $hit did Tekin create that it can't beat the GTB in a straight-up fight? =QUOTE]
Scott,
Why do you feel the need to be so abraisive? Even I bristled at this statement and I have been know to be a bit abraisive myself in local circles.
Are the kids more difficult to handle at school lately? Do you run out of hot water mid shower this morning? Did you dog run off with the neighborhood cat? Did someone "P" in your cheerios?
Ever since the Holliday break you have been a bit hard on USVTA folks here. Just a friendly bit of advise from someone who has personally crossed the line in the past. You need to back it down a notch or two Scott.
I know you don't mean to be mean.
Please take the previous as friendly advise. You have very valid opinions and advice, but your tone has the effect of diminishing your important messages.
I have learned, sometime it is best to decide if you are furthering the discussion or just 'back away from the keyboard' .
You friend.... Marty
Scott,
#7982
ford GT body, my local track will let us use them. So how well do they hold up? I just found out that I have to re-enforce my Cuda. Not that I have eny thing against doing this. But it seems that it will add a lot of weight to the car. I was going to do the Cuda with a light coat of shoe gue and then some 2 part epoxy. what do you guys think? How do you guys re-enforce your body's (first person that says dont hit eny thing should be sack tapp'd, hehehehe)
#7984
I use drywall repair mesh and ShooGoo. The mesh makes it much harder for the body to tear as well as provides a bit more "body".
The mesh has a light adhesive so it can be stuck to the body, then I smear liberal quantities of ShooGoo over it. Be careful how hard you press because moving the mesh around combined with the solvents in the ShooGoo will "erase" paint and make a mess. Get the mesh good and tacked down with the 'Goo then come back to get a finished even coating out to the edges.
I also use this method to attach "undercut" body pieces like the rear bumper/valance on the HPI Mustangs and 'Cuda and I've never had one come loose.
#7985
And a little tip on shoo goo if you didn't know... keep your finger wet when putting on the body. It will go on smoother and won't stick your finger as easily. Once it starts sticking to your finger... switch fingers.
#7987
Don't worry about a little Shoo Goo weight in VTA. It isn't a factor at all. Shoo Goo by itself... or with a little drywall tape or body mesh... or gap filling insulation... or anything you can come up with to make the body last a little longer.
I'm also experimenting with Gorilla tape in a few of the rub spots with good results so far. I also use it on the front bumper of my Pegasus Mustangs
Oh my...
#7989
Assuming the specs are correct in on the article, looks like Speed Passion has an entry for USVTA style racing:
http://www.redrc.net/2010/02/speed-p...club-race-esc/
New from Speed Passion, the Cirtix Stock Club Race ESC and motor combos finally give stock and spec class racers the fair competition they have asked for and all at an incredibly low price. The new systems are ideal for both big race spec handout systems and small club spec racing where equal performance and low cost are a must to grow new classes and attract new racers. The ESCs feature only brake strength and drag brake force as programmable options. All other performance parameters are fixed and there is no USB altering or updating capability in order to deliver the same consistent power for everyone.
#7991
Striving to exude all the humility and respect one can muster in a posting that asks a question of a question, as the case may be:
The release regarding the Speed Passion "spec" esc states very clearly that the performance parameters are "fixed", but it does not indicate the level at which they are fixed. I'm certainly no expert (merely a humble lay person) but it would seem fairly easy to "fix" the performance at some level of, say, timing advance or with some amount of what has become known as "turbo".
I am by no means suggesting that the folks at Speed Passion are attempting anything underhanded, I am just looking at this product as-described in the release. They describe it as a low-cost spec controller, as such are they saying that it would be (and very well may be) "spec" in the sense that if everybody is using it the spec is equal or are they saying that it would be ideal to meet the intent of a series like VTA where there are limited alternative esc's. I'm guessing the GTB, Havoc, etc don't have any advance, and certainly not dynamic advance...what I would be interested in seeing would be if the Speed Passion unit matches those parameters or not.
Those are questions that I would think have to be answered as any new (or re-purposed) esc is contemplated for addition.
#7992
vta bodies
I like the parma cuda myself, best thing i did was to put a third post behind the scoop made all the difference.And as far a weight goes i ran the whole hurricane series at 1569 grams like whoa im a sled but i guess the weight helps handling plus the cuda is i think the shortest body but it is a little bit taller than the pegasus shells....but hey thats just my opinion
Jc oaks
Jc oaks
#7993
THUNDER TRANS-AM SERIES
TRANS-AM RALLY 1000 MONEY RACE
Thunder RC Raceway in Nashville,TN
Sunday Feburary 28, 2010
Race Specification:
- Five, 10 minute mains
- Two man team
- Classes will include VTA and Jr TA
- Laps added for each team memeber for total laps
Money/Cash Payout:
$150- 1st
$75 - 2nd
$40 - 3rd
CONCOURSE WINNER RECIEVES EXTRA 10 POINT IN THE SERIES!!!!
RULES for the event:
http://www.usvintagetransam.com/rules/index.html
NO BOOST/TURBO/ADVANCE TIMMING ALLOWED
Format:
-racers can pick their own partners
-only 2 team members are needed
-random drawing qualifier will determine starting order
-re-sort after every round
-heads up Lemans start for every main
-round 1-4 will have both team members racing, and getting laps
-the final 10 min main will have 1 driver from each team,the other member will marshall
-laps will be added up to determine the winners
example....
Round 1
Team A: racer 1 with 23 laps, racer 2 with 25=48 laps for Team A
Team B: racer 1 with 25 laps, racer 2 with 26=51 laps for Team B
so Team B will start on the pole/1st in next round
Round 5/Main
the team will pick which driver will represent the team in the final 10 min main, the other member will marshall the race
ALL THE LAPS WILL BE ADDED FROM RD 1-5 TO DETERMINE THE WINNERS!!!
$15 ENTRY FEE....FOR ALOT OF TRACK TIME!!!!
Touring Car and 12th Scale are welcome to run on this day as well....
SPONSORED BY KRC & TRC
Race Specification:
- Two man team
Money/Cash Payout:
$150- 1st
$75 - 2nd
$40 - 3rd
Format:
example....
Round 1
Round 5/Main
#7994
#7995
Company Representative
You are correct to question fixed specs; one concern with spec products would be that they are all built to the same specifications. For instance timing can be added not only through PC adjustments, but also can be designed into the resident micro firmware.
A spec controller with a a small amount of built-in timing----say 5% or 10%---will have a significant advantage over speed controls designed with no timing and this may not be detectable.
As I have said before (many, many times....), the best solution for a spec controller would be manufacturers' offering stand alone, non-timing, non PC programmable escs. The manufacturers would be responsible (and accountable) for assuring customers and series directors that the controllers conforms to these rules.
This is definitely do-able. Other than USVTA, and maybe a few other series, "decision makers" are unwilling to decide. Lacking direction, the R/C industry is engineering its own demise. We, here at Novak, are definitely willing and capable of working toward this spec equipment goal.
Our dedication to this spec product segment should be obvious; we have been offering affordable, spec products/systems for well over a year. There is a simple solution--the spec products are available. But, there a lack of decisiveness.
All ROAR would have to do is set aside certain "spec/stock" events that require escs with the parameters outlined above, and mfgs could compete (within these guidelines) by offering the best products and after market parts and service for the price.
