Xray T3 2011
#661
#662
I ran my car for the first time yesterday, the car has a lot more rear grip than the T3 and the steering is much smoother. I was having issues with driveshafts for some reason yesterday I ran it 3 races, all 3 my rear driveshaft pins came out, and in the 1st race the whole rear driveshaft fell out Yes they were loctite'd. Then in the 3rd race i completely sheared a front driveshaft, just from driving. Oh well, time for some flat spot pins and stronger loctite. never had that issue on my T3.
I definatly need more time with this car as it wasnt driving perfectly yesterday. It needs more overally steering, and definatly needs more high speed steering. Anyone have any suggestions?
Here is the setup sheet
http://forum.teamxray.com/xform/inde...&setup=t3_2011
Here is what i was thinking of changing. Thoughts?
Thanks,
Antoni
Thanks,
Antoni
At the NSW State titles this weekend I was having LOTS of trouble with rear end grip on power. Ended up with a stiffer spring on rear, winder rear track, stiffer swaybar... and still stepped out at times, but was a lot better.
See you at the Nats!
Gav
#666
I think Ari also ran a thicker rear swaybar.
#667
Ant
I would just try going up in diff oil like 2000 filled. When I was testing diffs I felt that the lighter fuild let the car feel pushy on power when I went up in weight the car wanted to start to brake loose in the rear which gave me more on power steering.
Just my thought.
Thanks Drew
Just my thought.
Thanks Drew
#668
I want one. Was is the next shipment due out?
#670
here is mine
#671
Crowded in there. like mine, but yours is cleaner.
anyone hacked a Sakura diff in a T3 already?
#673
