Like Tree2Likes
Xray T3 2011
Old 10-29-2010, 06:34 AM
  #631
Does anyone know who sells 300,000 weight diff oil?
kobiwan is offline
Old 10-29-2010, 07:22 AM
  #632
Fred Hubbard's Avatar
Originally Posted by hanulec
...I can usually look at a board when running the XRay Aluminum Spool Cups and break blades.
LOL.
Originally Posted by kobiwan
What I meant was, will the stock blades fit inside the out drives of the Spec-R gear diff? I heard you had to use different ones but wasn't sure.
Yep they fit without any issues.
Fred Hubbard is offline
Old 10-29-2010, 07:38 AM
  #633
Drew Ellis's Avatar
Xray sells 300,000 diff oil.
Thanks Drew
Drew Ellis is offline
Old 10-29-2010, 08:48 AM
  #634
Trader Rating: 16 (100%+)
Hi guys, I am new to XRAY products. My question is, which car, T3 or T3'11 has a bigger sweet spot in terms of finding a good setup. Also what is the difference between the handling of these 2 cars? Are the lap times very different?
ronaldo-1234 is offline
Old 10-30-2010, 07:37 AM
  #635
Hey Drew, do you run the ECS drive shafts? Also, I plan on running a gear diff in the front, is it still good to run ECS drive shafts when using a gear diff? From What I understand it is recomended to run the ECS when running the spool, but wasnt sure if they were as important when running a gear diff.
kobiwan is offline
Old 10-30-2010, 08:58 AM
  #636
Originally Posted by Fred Hubbard
Yes they do because the plunge point is different so the car reacts faster, especially on tracks with chicanes. Most of the team here in the states run the 50mm bones the majority of the time.
Thanks Fred
kobiwan is offline
Old 10-30-2010, 09:22 AM
  #637
mickrcarver's Avatar
Trader Rating: 101 (100%+)
Thanks Fred
John,you still run Xray?? awesome!!
mickrcarver is offline
Old 10-30-2010, 10:26 AM
  #638
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Originally Posted by R Dodge
Have you tried taking 2 of the 1mm plastic shims that come with the kit, cutting 2 parallel flat edges on them and place a shim behind the cup on each side to make the spool 2mm wider overall?
I like that idea.
andrewdoherty is offline
Old 10-30-2010, 10:38 AM
  #639
Thanks Fred
You're welcome
Old 10-30-2010, 10:49 AM
  #640
SammyZ's Avatar
Trader Rating: 138 (100%+)
I am so awesome.
you are my hero
SammyZ is offline
Old 10-30-2010, 11:13 AM
  #641
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by B18C Turbo
you are my hero
Its good you hear u r racing again.. ill probably see u u
p at Madness soon...
hanulec is offline
Old 10-30-2010, 12:15 PM
  #642
Drew Ellis's Avatar
Yes, at the Halloween race I ran a front gear diff with the ECS's. And yes the ECS's are setup more for a spool. I feel that they are always good to run, but the feeling my be more noticeable with the spool. But I dont think they hurt it. I run the 52s ECS's in the front with the standard 50s in the rear.
Thanks Drew
Old 10-30-2010, 12:19 PM
  #643
Drew Ellis's Avatar
The T3'11. I have been faster with mine, feel that the car makes more traction over all then the T3. The car is still really new so I am sure we will learn more about the car. Mine and Paul's setup are on line at www.teamxray.com. I think these are really good base setups.
Thanks Drew
Old 10-30-2010, 12:31 PM
  #644
Regional Moderator
CarbonJoe's Avatar
No, not "still", but "back to". It went T3, TOP Photon, Tamiya 416, now back to a T3 '11.
CarbonJoe is offline
Old 10-30-2010, 12:50 PM
  #645
LOL guess he learned his lesson
