Rody VS Racing Engines - Onroad Motors >
Like Tree138Likes
Old 11-04-2017, 10:58 PM
  #151
Originally Posted by rick oxley
never heard of this before does this work when the engine has lost some
compresion instead of a liner pinch?
Yip- that is it. Often also can recover a liner that has been overheated.
You can experiment with slightly higher temps than a domestic oven if you have access to an autoclave or similar.
Do not use direct flame. Stick it in the oven for 20-30 minutes then let the sleeve cool naturally in the oven or out but do not quench. It basically relaxes some of the stretch put in by the heat cycles.
Especially useful on a motor that has just lost that 'edge'
JTeamtech is offline
Old 11-06-2017, 09:11 AM
  #152
Especially useful on a mother that has just lots that 'edge'
I tried this with 3 of my motors over the weekend and it does work!
nitrodude is offline
Old 11-07-2017, 02:22 PM
  #153
am
Have you tried running the engines afterwards?
am is offline
Old 11-08-2017, 12:45 AM
  #154
VS_Rody's Avatar
Originally Posted by ralphierace13
rody when u say finish the process over the next 4 tanks, do u mean 4 tanks in a row or cooling in between each tank then reheating and starting?
I do not let the engine cool down between each tank. I just run the 4 tanks is a row. But you can do the cooling-down in between also. Just take it easy the 1st minute on the track when you start driving again.
VS_Rody is offline
Old 11-10-2017, 03:44 AM
  #155
Default VS03
Hi Rody,
I just saw the VS03 just launched, couple of questions would like to know.
Is it based on R2103? I've found both crankcase on 02 & 03 are same, but P/S, crank shaft are different. Also the in/ex port timing are same as previous models. Just wondering your spec isn't related to R2103. What kind of improvement will be find on VS03?
beebone is offline
Old 11-10-2017, 05:29 AM
  #156
VS_Rody's Avatar
Originally Posted by beebone
Hi Rody,
Hi BeeBone,
Yes, it is based upon the R2103 but since OS has gone back to the steel main-bearing the difference are not so important.
Compared to the VSR02 the VSR03 has a different crankshaft timing, it closes 5° earlier, which improves the low en rpm torque and also fuel-efficiency. I also made some extra work on the inlet of the crankshaft to have less turbulation.
On the sleeve, the shape of the exhaust port has been changed, this to make more efficient the changed inlet timing of the crankshaft.
Of course we still use our own design combustion chamber which also makes a difference.
The difference we have found is that compared to the VSR02 the VSR03 has more power on the low rpm area and is much more responsive on the throttle. While the VSR02 seemed a little more elastic on the throttle.
I just released a complete kit for to transform your VSR02 into a VSR03 engine.
You can find this kit here: VS12001
Check out the other spare-parts of the VSR03 engine HERE
AMAIN has just received the first VSR03 engines for whom is interested.
Hope this has helped you further.
Pedro Jesus likes this.
VS_Rody is offline
Old 11-10-2017, 07:39 AM
  #157
ralphierace13's Avatar
Originally Posted by VS_Rody
Hi BeeBone,
Just curious the head button in your upgrade kit is it different then the stock one?
ralphierace13 is offline
Old 11-10-2017, 08:42 AM
  #158
VS_Rody's Avatar
It is the same, it has only an additional silicone o-ring to keep the area inside the engine cleaner.
I am selling it also separately as an optional, they are not mounted on the original engines because I make only limited qty's, you can see these here: VS02002
VS_Rody is offline
Old 11-10-2017, 12:44 PM
  #159
GREGORY!'s Avatar
Os speak about lower exhaust in R2103 and different timing in crank.
You did change only the crankshaft?
Or the exhaust was already lower than R2101-02?
GREGORY! is offline
Old 11-11-2017, 12:08 AM
  #160
rody the markings ontop of head on the carb side that has the numbers 20,30,40,50 does that mean something?
Old 11-11-2017, 01:20 AM
  #161
VS_Rody's Avatar
No Lower exhaust timing on the OS R2103 compared to the older versions, just a change of the shape(which makes a difference).
VS_Rody is offline
Old 11-11-2017, 01:26 AM
  #162
VS_Rody's Avatar
This supposed to represent an rpm meter, I just discover the x1000 is missing on the design.
There is a small arrow in between the 40 and 50(48) so the engine can go up to 48.000, of course max rpm.
Just a thing to make a difference in look. On the buggy engine this has come out better then this one.
VS_Rody is offline
Old 11-11-2017, 05:12 AM
  #163
Rody your VSR03 or VSR2103 will always go up to 48,000 RPM?
Pedro Jesus is offline
Old 11-11-2017, 07:33 AM
  #164
VS_Rody's Avatar
Yes, it can reach this rpm but it's a red zone to be not too long for the engine.
VS_Rody is offline
Old 11-11-2017, 12:07 PM
  #165
Yes I understand in these very high regimes it is not advisable to walk there long.
Because otherwise Motors will not last long.
But having a very high regimen sometimes may even be good for doing that bit more of TOP SPEED than the other competitor.
I like to follow your topics here in the forum.
Rody your VSR03 is priced very well Congratulations.
VS_Rody likes this.
