Rody VS Racing Engines - Onroad Motors
#121
We made our own designed carburetors some time ago when I was producing the TecnoPower engines. I used these same carburetors on the VSR01, you can see it here.
Unfortunately we cannot reproduce because of the qty of engines we sell are not enough. So I decided to use the OS carburetor which is a very good design too and the quality and finish is really up to a good standard for me.
#122
Hi Pedro,
#123
rody did u know on the os carb there is a sleeve that is press over the barrel part that goes down into the motor it is not a one piece, it has come loose on me 3 times on 3 different motors. I believe the nova is a one piece design or it might be 2 also just has never come off before like my os has. did u know that?
OS has chosen to use a steel sleeve pressed(and glued) with precision on the barrel part of the carburetor itself. A steel sleeve is used because the aluminum of the carburetor is too soft and when you tighten too much the carburator fixation then you risk to deform and the carburator can get stuck in the housing. Using a steel sleeve this will not be possible. Of course if you over-tighten the fixation you also deform with the result the sleeve can come loose from the barrel.
However this can be fixed by degreasing(breakcleaner) well the barrel part of the carburetor and making some small flat parts on the barrel part so the glue can settle there and hold better the sleeve in place. Make some smalle groves inside the sleeve with a dremel too. Then clean well and assemble with loctite 648, remove all the exsessive glue and let it dry for 24H
Nova has chosen to insert the steel ring during the casting process and with this for sure the ring will never move. However this is not an easy process, slow and quite expensive to realize.
#124
Hey Rody,
I havent been able to read this whole thread but do you know if anyone in California/GLARCRC is running this motor ? Thinking of getting one but know I will need help with break in and getting it set up.
#125
You can find him on page 3 of this thread.
#126
#127
#129
Yes, I am aware how both of these are made.
#130
I'm local and can also help you break it in if time permits. Just pm me with any concerns if you start yourself
#131
#132
No, I'm near that track. Heat gun, temp gun and a few other things help it go smooth. You just need the car with good initial settings or a break - in bench. If you don't get it done pm me a contact number, I'll buzz ya to go over it. I can lend a hand or walk you through it.
#133
Hi HSV427,
To be honest, no I do not think that there will be major difference, only small differences can be obtained today. Since the VSR02 has some modifications made to the crankshaft and combustion chamber there will be better power in the bottom and mid-range normally
Mileage should be about the same but this depends also a lot on your way of driving.
VS302098M2001
Power*****
Fuelconsumption***
VS302115M32
Power****
Fuelconsumption***
VS302069M32
Power***
Fuelconsumption****
Please note that the * are just to give an indication on the difference. The difference itself is very little between the combo's.
Hope this has helped you further.
Power*****
Fuelconsumption***
VS302115M32
Power****
Fuelconsumption***
VS302069M32
Power***
Fuelconsumption****
Hi Rody, exactly what you say.
I have 2 VS-R02 engines (you know), and 2 OS-R2102 engines, and the difference between them is exactly that.
The difference between the exhausts is also my conclusion, in where the OS-2080 / EFRA 2098 gives most power everywhere (and best sound
Next season I will continue to run your engines, I will contact you in due time.
Good luck, and most of all enjoy your time at the worlds next week. I will not attend... sometimes you have to make choices.
#134
This would be the best solution for me personally, the only thing is that this is not for everybody because you have to be careful not to over-tighten too much the carburetor retainer.
#135
Hi HSV427,
The power delivery compared to an OS2102 ( even if modified ) is that it produces immense torque on the low end yet complements the midrange the original engine has compared to a very midrangey only character of the OS 2102 making the power delivery immediate which benefits technical circuits like ours.
The motor came off just under a 100 deg C and I felt it as already too powerful thus have dialed it down slightly on the top end needle but Rody's motor really surprised me, Guys that normally run the 2102's here started turning heads to see the immense power delivery of this motor from bottom right up to the top at the end of the straights.
Kudos to you Rody for creating one fine motor!
