U.S. Vintage Trans-Am Racing
#7636
For the Ballistic it couldn't be much easier to understand. You've got a "neutral" position (N) which I don't hope to understand (much less explain) how it is selected other than it's some high-tech engineering sh*t) and you advance or retard timing from that point. The motors/mfr's that need to do a better job of teaching are the ones that have labels like I've described...because I'm quite certain you'll find that their " 0* " is not zero degrees, that they are also operating from a base timing that is significantly removed from zero as well.
#7637
Company Representative
Motor timing is generally the last step in motor assembly; if you replace your stator or rotor, the timing changes. Also, if your existing rotor weakens, the timing changes.
#7638
I was hoping more for something like 5,10,15...45 degree numbered marks. I personally don't like the N reference point and +/- marks.
Too many people think N = 0.
Novak Two:
Please tell us more about rotor changes (new vs tuning) and weakening and how that affects timing. We're listening.
#7640
That's got to be some kind of record for self-contradiction! JK
Novak Two:
Novak Two:
#7642
As for the current non-approval status, I don't believe its a manufacturer submittal issue, as from what I understand from what I have been reading, there are no rules currently at ROAR to submit the packs for, and some manufacturers are probably waiting to submit the stuff once there are ROAR rules.
ROAR has clear rules about battery approval. Samples must be submitted to ROAR for approval. Right now there are no rules specific to Life, so it would be up to the manufacturers to work with ROAR on what the specs should be, and how to enforce them. I think it took 2 years of research and working with manufacturers to get the LiPo rules worked out.
#7649
And thats's no disrespect to Novak you guys have great service and do pissin around very well.
