HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 07-27-2011, 03:35 PM
  #31
pavmentsurfer's Avatar
Trader Rating: 83 (100%+)
Im looking to power a Castle 3800 4 pole motor and wondering if I can get away with the 80 amp XErun ESC (blue case) or do I need the 150amp? Ive never measured an ESC by the amps it can handle, I have always purchased motor/ESC combos based on manufacture specs. Not sure what kind of amps id need to run this motor. Id also like to be able to power the 2400KV castle motor with it once and a while.
Any help here would be great.
pavmentsurfer is offline
Old 07-27-2011, 04:00 PM
  #32
proraptor's Avatar
Im running a 4 pole 3800kv castle on my 60 amp EZrun esc and it works awesome....These ESC's are under-rated IMO
proraptor is offline
Old 07-27-2011, 04:49 PM
  #33
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Yes u can, no problem at all.
SuperEk4 is offline
Old 07-27-2011, 05:39 PM
  #34
Awesome... thanks guys. I cant imagine what youd need the 150 amp ESC for then... maybe a 1/5 conversion or something?
Old 07-27-2011, 06:09 PM
  #35
SuperEk4's Avatar
1/8 to 1/5
SuperEk4 is offline
Old 08-05-2011, 01:27 AM
  #36
gogi108's Avatar
hi recently got a 10.5 xerun combo that has black 60a esc , when setting throttle trim pressing the button on the switch the thing just beeps and flashes red light . in the manual it says this is a voltage issue . i ran the car anyway and it ran fine but is hard to engage reverse . has anyone had this happen or know what i'm doing wrong . thanks
gogi108 is offline
Old 08-05-2011, 04:08 AM
  #37
I am have my 60A cutout while running my car. Motor will stop, ESC LED will flash green after a few moments, it will run again. Even if the battery is freshly charged. The ESC and the motor are not getting hot. Any ideas?
rahzip is offline
Old 08-05-2011, 08:01 AM
  #38
SuperEk4's Avatar
The reverse is abit slower, try adjusting the trim
SuperEk4 is offline
Old 08-05-2011, 08:02 AM
  #39
SuperEk4's Avatar
What batts are u running n wat LVC are u at?
SuperEk4 is offline
Old 08-05-2011, 02:21 PM
  #40
Trader Rating: 36 (100%+)
Default HobbyWing 1/8 Scale C-Xerun 80A Brushless ESC on 2s
Any one run the HobbyWing 1/8 Scale C-Xerun 80A Brushless ESC (blue case) on 2s? i am looking to run one in a Losi SCTE powered by a 2s lipo, motor will be a trinity 550 sc motor 4.5turn.
mfcplflo is offline
Old 08-05-2011, 03:49 PM
  #41
SuperEk4's Avatar
Yes you can, but i will suggest 120amp xerun for 1/10 is better. Smaller, lighter n meant for 1/10 cars.
SuperEk4 is offline
Old 08-05-2011, 05:46 PM
  #42
11.1V 4000MaH & 4400Mah Low Voltage Cutout 3.2V. I have used different brands.
rahzip is offline
Old 08-05-2011, 06:23 PM
  #43
SuperEk4's Avatar
I think 3s is too much for the esc, check the temp can't be over 80 degree. Try 2s
SuperEk4 is offline
Old 08-06-2011, 05:37 AM
  #44
gogi108's Avatar
thanks mate , i got it sorted . i have 10.5 xerun and am a bit worried about dirt ect getting in and killing it . should i be worried ? what are peoples experience with this ? cheers
gogi108 is offline
Old 08-06-2011, 06:07 AM
  #45
SuperEk4's Avatar
No it's fine just don't wet it too much, u may jam the bearing.
Just clean it after use.
SuperEk4 is offline
