HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree192Likes
Old 08-02-2012, 11:30 AM
  #781
Trader Rating: 22 (100%+)
Thanks for the help everyone. I thought it would be like the sc8, my dumb mistake. I got it now.
Originally Posted by lewis110
I believe the 150amp esc still uses the wire you plug into the receiver. The v3 and SCT pro uses the fan port on the esc.
jonasm48 is offline
Old 08-02-2012, 07:09 PM
  #782
Originally Posted by Cloaked
So is there a way to reset the LCD Progam Box?
I think I bricked mine with a firmware update....
When I connect it to teh PC it just shows Squares....
I didn't see any response to this but I have a 2 in 1 box that does the same thing.
Anyone have a solution?
Troy Carter is offline
Old 08-02-2012, 07:18 PM
  #783
I posted in a different thread but it looks like this may have been the right one...
This evening I ran my brand new HW ESC for the first time. This is an XERUN 150amp ESC on 4s. I ran for about 4 or 5 minutes on the track, then I just lost throttle completely like it hit the voltage cut. Turns out, it wasn't the low voltage cut though.
I tried two freshly charged batteries, and had no throttle. Just a blinking red LED on the ESC at first. I checked all my tx settings, checked throttle signal, checked wiring, checked ESC settings..all good. Eventually, the blinking went away and I just had a solid red LED on the ESC. After that, I found that the motor would run, seemingly fine, until I let off the throttle and let it stop. At this point, there would be no LED lit on the ESC. Then when I pulled the trigger, it would not run the motor again and the solid red LED came back on. I was able to 'push start' the car, then it would run fine again.
This was pretty repeatable. Push start, run fine, stop, no throttle response. Push start, and repeat. This was all with a Tacon 2000kv 1/8 motor by the way, in an RC8.2e with stock spur and 18t pinion. After the first run, the motor and ESC temps were reasonable...I forgot my temp gun at home but I could easily hold my fingers on either indefinitely. When I got home, I tried a Castle motor to see if the problem would persist, and it did. So the problem is definitely with the ESC I think.
Any ideas? If it's bad, what's the best way to get it replaced?
Overtorqued is offline
Old 08-02-2012, 08:08 PM
  #784
Cloaked's Avatar
Trader Rating: 15 (100%+)
One of the other guys posted a fix.
Just manually force it down to the program box again and mine was ok.
Cloaked is offline
Old 08-02-2012, 10:32 PM
  #785
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Falcon sekido can help you guys out.
Also I will try my best to help u guys out just pm me.
team driver Cale Rockey
hobbywing Canada
Blitzrockey is offline
Old 08-03-2012, 06:17 AM
  #786
lewis110's Avatar
You have to hook the program box back up to the computer and redownload the filmware into the lcd program box. Flash it twice just to make sure its downloaded properly.
lewis110 is offline
Old 08-03-2012, 06:44 AM
  #787
hyper9boy's Avatar
Is HOBBYPOWER and LEPARD. Made in the HOBBYWING factory
They both look the same
Thankyoy
hyper9boy is offline
Old 08-03-2012, 11:06 AM
  #788
I've tried that several times with no luck. The programmer still just shows boxes on the LCD. I'll get a shot today on a different computer.
Old 08-03-2012, 11:54 AM
  #789
SureShotImages's Avatar
Is the motor sensored? If so, check your sensor wire.
SureShotImages is offline
Old 08-03-2012, 12:00 PM
  #790
It's sensorless.
Old 08-03-2012, 12:41 PM
  #791
is there a place in the US to buy a xerun sensor wire? or is the wire generic and can find a sensor wire somewhere? mine just got ate up unfortunately.
jonasm48 is offline
Old 08-03-2012, 01:23 PM
  #792
You can run any sensor wire that you have if need be.
Old 08-03-2012, 01:47 PM
  #793
lewis110's Avatar
www.falconsekido.com
www.teamcrc.com
lewis110 is offline
Old 08-03-2012, 02:59 PM
  #794
lewis110's Avatar
Just to clarify you are plugging just the program box in and reflashing just the box?
lewis110 is offline
Old 08-03-2012, 03:22 PM
  #795
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
hey guys im going to throw a extreme stock on my losi 22 buggy do i need to run the fan?
BlackStarRacing is offline
