HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 12-31-2012, 02:47 AM
  #1531
evostyle's Avatar
Trader Rating: 103 (98%+)
The case is held on with two screws (jewelers phillips) on the bottom, two snap tabs on the side underneath the stickers. I just peeled up the stickers and "unlocked" the tabs. Then it should open up. Take your time peeling up the 1s heat sink off the mosfets so you don't damage the heat transfer tape. Then put the heat sink in the top half with the tape between the heatsink and mosfets and close it up.
evostyle is offline
Old 12-31-2012, 02:53 AM
  #1532
evostyle's Avatar
Originally Posted by froggie22
Similar set-up to what I'll be running. It's a b44.2 with a 8.5t.
I'm running a 7.5 on a small to medium sized track. Stock spur with a 20T pinion. Punch at level 3 is really smooth. I'm also running just a small amount of boost timing (function 9) set to value 2 ( 3 degrees ) with no turbo and the car is a ROCKET! I think a lower punch value really helps to make the traction controllable outta the turns which really makes it accelerate hard.
evostyle is offline
Old 12-31-2012, 12:54 PM
  #1533
BillyT.'s Avatar
Xerun 150a running the most recent firmware I can find and the temp protection drop down is grayed out on the USB link software... And there is no option for it on the LCD programmer. maybe... I need to check this again...
Any insight?
BillyT. is offline
Old 01-01-2013, 08:42 AM
  #1534
robbieg's Avatar
Trader Rating: 26 (100%+)
ordered from http://www.falconsekido.com/ and there service is great.
robbieg is offline
Old 01-04-2013, 12:14 PM
  #1535
Default need help with program card
Hi I have a ezrun 3656 4000kv I can't get the program card to work it comes on with straight lines no numbers
mrsnake is offline
Old 01-04-2013, 01:41 PM
  #1536
thebizz's Avatar
Trader Rating: 52 (100%+)
What firmare and software do I use with the SCT pro and HW 3656SD 4700kv?
thebizz is offline
Old 01-04-2013, 01:46 PM
  #1537
Suspended
Trader Rating: 440 (99%+)
+1
I ordered three xerun 150a escs from them in the last couple weeks and their shipping was super fast.
MattP is offline
Old 01-04-2013, 02:17 PM
  #1538
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
There is just the firmwear that comes with it, at the moment its not upgradable etc.
Blitzrockey is offline
Old 01-04-2013, 02:37 PM
  #1539
Slotmachine's Avatar
Make sure the 3 color wire is hooked up right and you have a good charge on your battery. I have never seen this happen before...............Make sure the program box has the latest update in it.
Paul R.
Slotmachine is offline
Old 01-04-2013, 02:40 PM
  #1540
Download and install the latest software there is.......................
Old 01-04-2013, 02:46 PM
  #1541
Trader Rating: 21 (100%+)
For you guys running the 120a sct pro and a 4 pole motor, do you notice any difference between punch and timing changes? I've tried multiple settings and I cannot tell (gps verified) any change. Whereas I have a viper esc and it's night/day difference when timing and punch kick in.
mulepic is offline
Old 01-04-2013, 03:00 PM
  #1542
Any insight?
Same here! Which is the latest firmware for the ESC and prog.box?
carpediem is offline
Old 01-04-2013, 03:27 PM
  #1543
lewis110's Avatar
You need to hook just the program box up to the usb pc software and reflash the box. Sometimes this happens, but its an easy fix.
lewis110 is offline
Old 01-04-2013, 03:42 PM
  #1544
Suspended
I found the download page for the software. Which version should I use for the xerun 150a escs?
http://www.falconsekido.com/pages/download
I downloaded the latest software and it says it can't open this type of file....Anyone else get an error message?
MattP is offline
Old 01-04-2013, 03:46 PM
  #1545
robbieg's Avatar
mine downloaded and works fine except for the grayed out temp protection
robbieg is offline
