Tekin RS ESC sensored >
Old 11-05-2009, 07:17 AM
  #8011
niznai's Avatar
Originally Posted by 20 SMOKE
other than the size and able to handle low turn there almost the same but there is no sensored mode for use with high turn which means no boost,turbo
What turn do you need to run?
niznai is offline
Old 11-05-2009, 08:14 AM
  #8012
Krio's Avatar
Trader Rating: 159 (99%+)
Originally Posted by InspGadgt
I tried to find the post, but I don't have time right now. I could have sworn the RX8 is an RS in a bigger case with better cooling. That means it will do everything the RS will, just with better cooling and more weight.
I also recall people going to the RX8 in mod class because it was better at cooling.
The RX8 is based off the RS and is very similar. However, because it was designed for multi-pole high voltage motors the sensor only function is locked out in the software. Sensors are not as accurate with multiple poles/slots so sensored only is actually detrimental in 8th scale electrics. Thus to protect the uneducated public sensored only is not available on the rx8. I'm sure you could "jailbrake" it though...
Krio is offline
Old 11-05-2009, 08:54 AM
  #8013
F-1
Yes, i need RS PRO. I live in Russia, and i cant buy it your local shop
F-1 is offline
Old 11-05-2009, 09:09 AM
  #8014
Team Tekin
Randy_Pike's Avatar
The RX8 was tested in extreme mod TC using Lipos, 5 cell with motors down to a 2.5t.
It doesn't have the ability to go into sensored only mode which is fine since in MOD you're not going to want that. It works just fine as it shares programming with the RS line.
Randy_Pike is offline
Old 11-05-2009, 02:09 PM
  #8015
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by stiltskin
Does the amount of turbo affect the top speed or just how fast it gets to top speed? Also is there a limit to the amount of timing and turbo? I know motor and speedo timing should be kept around 30, but is there a relationship between timing and turbo as well? Thanks.
Randy???
stiltskin is offline
Old 11-05-2009, 02:15 PM
  #8016
Krio's Avatar
Randy???
Turbo affects top speed...it does not provide extra acceleration to obtain your top speed quicker. The maximum on the Turbo slider is 20 degrees of timing.
The 30 degrees reference is a suggested maximum between motor timing and boost timing. Turbo is an addition of timing and is capped at 20 degrees maximum you can add.
Krio is offline
Old 11-05-2009, 02:37 PM
  #8017
stiltskin's Avatar
Thanks Krio. I'm going to keep adding turbo until I'm happy.
Old 11-05-2009, 04:19 PM
  #8018
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Timing? Turbo? I heard a rumour that software developers hidden in secret locations are trying to code N2O (Nitrous Oxide) into a future release
PDR is offline
Old 11-05-2009, 04:24 PM
  #8019
mtbboy's Avatar
Hey all.
I know this has probably been covered a zillion times on this forum.
When I punch the throttle on my rs pro the car stutters and then launches.
What am I doing wrong here?
Dave.
mtbboy is offline
Old 11-05-2009, 05:12 PM
  #8020
stiltskin's Avatar
Originally Posted by mtbboy
Hey all.
Dave.
Try a new sensor wire.
Old 11-05-2009, 06:09 PM
  #8021
Yup try a new sensor wire...if that doesn't work then clean out the motor really good with motor spray. Sometimes dirt can get on the sensors and cause the same problem.
InspGadgt is offline
Old 11-05-2009, 08:09 PM
  #8022
Krio's Avatar
No...do NOT use motor spray on sensored motors. Compressed air is the best way to clean them out. Motor spray can damage the electronics in the motor.
Krio is offline
Old 11-05-2009, 09:19 PM
  #8023
reenmachine's Avatar
Trader Rating: 26 (100%+)
Hey all.
Dave.
Remember that you can check the sensors via the last three LEDs on the ESC. Power everything up and turn the motor while watching the LEDs. They will light (dimly) as each of the three sensors is triggered. If one or more of them never flashes check/replace your sensor wire.
reenmachine is offline
Old 11-05-2009, 09:21 PM
  #8024
niznai's Avatar
Krio, if motor spray is isopropylic alcohol is it OK then to use it on the sensors? Isopropylic alcohol is sold as "electronics cleaner" under a lot of brands and it is especially for cleaning electronics (I have been using it for a long time with all my other speedies and all sorts of other electornics as well, without any problem) as it does not attack plastics and evaporates without residue.
niznai is offline
Old 11-05-2009, 09:27 PM
  #8025
Krio's Avatar
Isopropyl alcohol isn't a problem. The problem is that all the motor sprays that I've ever owned usually contained one or more of the following:
Hexane, Propane, Isopropanol, n-butane, and Isobutane. While plastic friendly for the most part, they are not ideal for electronics.
Krio is offline
