Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 05-12-2009, 08:12 AM
  #16231
xraysteve's Avatar
i was asking for a friend. my xray is great.
xraysteve is offline
Old 05-12-2009, 09:39 AM
  #16232
JayL's Avatar
need more rear in-corner grip
already running 3 degree per side toe
have tried every spring/oil combo and droop settings
I'm thinking roll centers, where is the best place to shim to get more roll in the rear?
JayL is offline
Old 05-12-2009, 09:41 AM
  #16233
TheCoolCanFanMan's Avatar
Originally Posted by Lazer Guy
Yea.....Get a Cyclone You know you want one
That I know of your Xray never hooked before ?????
As you know my Cyclone hooked and the only way I could stop it then and still have good steering was to use a heavy sway bar and lighter springs on the front.
We both have changed many things, I'm not sure what I changed that stopped my hook but I don't seem to need the heavy sway bar anymore
One of the things I changed was I now have more ackerman action then I ever had before.
Guys......Could more ackerman stop an on power hook coming out of a turn????
If you have 4mm Ackerman then reduce it to 2mm it wont be so aggressive turning in, which stops the back from following the front round to quick, you may feel the steering being a bit numb, but it will smooth the car out
TCCFM
TheCoolCanFanMan is offline
Old 05-12-2009, 10:18 AM
  #16234
xraysteve's Avatar
TCCFM
so to turn easiers you want more of a angle or less
Old 05-12-2009, 10:26 AM
  #16235
Trader Rating: 32 (100%+)
1.5 under the hinge pin blocks is a good starting place.
racenut123 is offline
Old 05-12-2009, 03:43 PM
  #16236
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Didnt you used to run a Tamiya? I didnt even notice you had a cyclone last time i was at the track lol!
BlackedOutREVO is offline
Old 05-12-2009, 04:38 PM
  #16237
JayL's Avatar
I will always run Tamiya unless huge $$ comes my way
But I work on other people's cars.......
JayL is offline
Old 05-12-2009, 04:41 PM
  #16238
Trader Rating: 40 (100%+)
I know when the rear end in my car would step out I tried everything.. Then I saw one of hara set up sheets and he had the bigger spacer in the rear hubs in front and the little spacer in the rear of hub. Hopefully it make sense if not hit me up with a pm.
King of B Main is offline
Old 05-12-2009, 05:16 PM
  #16239
JayL's Avatar
so shim the rear arms back, longer wheelbase. I will check it out
JayL is offline
Old 05-12-2009, 05:23 PM
  #16240
EJ20's Avatar
He said the rear HUBS.
EJ20 is offline
Old 05-13-2009, 09:20 AM
  #16241
JayL's Avatar
ah, duh, space the hubs back
JayL is offline
Old 05-13-2009, 10:59 AM
  #16242
I'm curious about switching the shims in the hubs around myself and wondering if it will make the rear end of the car follow through with the front any better.
airwoods is offline
Old 05-13-2009, 11:03 AM
  #16243
JayL's Avatar
will post up after testing
JayL is offline
Old 05-13-2009, 11:18 AM
  #16244
It worked for me and I looked at all the team drivers cars here in SoCal and they are running it that way..
Old 05-13-2009, 11:50 AM
  #16245
STLNLST's Avatar
Good luck.
STLNLST is offline
