Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 05-08-2009, 03:00 PM
  #16201
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by STLNLST
Just remember that I didn't get the name KING OF THE STRAIGHT for nothing. This weekend will be fun though. Especially if I get on the mic.
LOL. I guess if you arent fast in the infield, be fast on the straight!
Haha jk. I will for sure be at REEDY hanging out in the pits with you guys. You guys are way to effing funny!
BlackedOutREVO is offline
Old 05-08-2009, 03:04 PM
  #16202
R/C Tech Elite Member
JayL's Avatar
Korey: correct, Thank you
JayL is offline
Old 05-08-2009, 06:08 PM
  #16203
Team STPN's Avatar
Originally Posted by JayL
you are actually racing?
<mechanic hat>
hey, in the Hara build up website he puts a spacer in the diff. Do you not need/want that in the world spec diff?
</mechanic hat>
Yup see ya tomorrow
Team STPN is offline
Old 05-08-2009, 06:59 PM
  #16204
GasGod's Avatar
Is there a known problem with the cyclone s tub chassis?I have broken two in the past week.Afriend of mine who just started racing tc has broken his also.Mine was not hit in the rear and I didn't hit anything- I ran over a corner dot--the last one I didn't hit anything and there was no one else on the track at the time.I did note some rear chatter but that is common with a tub and dogbones...All three have broken in the exact same place-between the rear toe block and the last set of rear bulkhead screws,where the belt slot is.I know its only plastic/nylon but jeese- it is quite frustrating to a newbie-and in my opinion that is really what this car is for(new drivers)it should be at least able to take a hit or two without the whole rear of the car falling off-.I bought this car to replace my xxx-s graphite,which by the way has never broken anything besides a c-hub or two in the seven seasons I've had it.I'm gonna try it again sat.race- i run 13.5 rubber outdoors but will go down to 17.5 to try and keep it together-I love the way the cyclone handles but this chassis-breaking is nutz does anyone make a good graphite one for the sport??
GasGod is offline
Old 05-08-2009, 07:54 PM
  #16205
mangoman's Avatar
Do you have a throne on the straight, which is your designated marshalling spot
mangoman is offline
Old 05-08-2009, 09:30 PM
  #16206
Trader Rating: 14 (100%+)
Got the Pro diff and aluminum shocks tonight. The pro diff i awesome! Only drawback i see is you cant adjust it in the car right?
DG Designs is offline
Old 05-08-2009, 10:13 PM
  #16207
That's just one of the many reasons I quickly sold my Cyclone S. You could just buy the lower CF deck to prevent that problem if you think its worth it.
RC-DriftNewb is offline
Old 05-09-2009, 03:13 AM
  #16208
Hi, you can adjust it in the car, just get a thin 1.5mm hex driver and slip it into the short outdrive whilst the diff is in the car, align the screw head and you should be able to adjust the diff!
Green Speed is offline
Old 05-09-2009, 08:32 AM
  #16209
I thought of that but the screw head doesn't seem to get to the edge of the out drive. I ll have to check again in better light. Thanks. By the way as far as the tub breaking i cut the back off all the way to the edge of the rear suspension mount. That extra area behind could give a fair amount of leverage on an area that does not have a lot of support. Trust me i stress tested it a lot last weekend and it is still ok
Old 05-09-2009, 09:50 PM
  #16210
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Team STPN
Yup see ya tomorrow
I was fast 2day
STLNLST is offline
Old 05-09-2009, 09:57 PM
  #16211
Team STPN's Avatar
I was fast 2day
Lucky.....
I you sure everyone else wasn't slow.....
Old 05-10-2009, 09:46 AM
  #16212
jag88's Avatar
Korey, what is the latest and greatest shock towers we should be using ? I've come up with three different part numbers and don't know what the difference is between them other then one of them is 3.5 mm thick. Front and rear.
Also what is the part number for the shock o-ring we should be using ?
Have you ever tried Tamiya o-rings ?
Thanks.
jag88 is offline
Old 05-10-2009, 10:47 AM
  #16213
SammyZ's Avatar
Trader Rating: 138 (100%+)
jag-The WCE towers are very nice, lots of shock mounting options! The TC towers are very similiar but if im not mistaken may be a touch (1mm?) taller or shorter than the WCE towers.
Im using HPI #6820 Silicone O-ring with great success, I have been told it is the same silicone O-ring used in the Tamiya TRF dampers, but I will confirm this myself later this week!
SammyZ is offline
Old 05-10-2009, 05:21 PM
  #16214
STLNLST's Avatar
Lucky.....
I told everyone that when I was done testing motor and speedo's I was going to get the set up dialed
STLNLST is offline
Old 05-10-2009, 06:05 PM
  #16215
tc3 racer sc's Avatar
Originally Posted by Jonnydb
hey superior hobbies.com hve them i bought one last week im waiting may get it tomorrow
tc3 racer sc is offline
