1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2923Likes
Old 11-08-2020, 02:22 PM
  #15406
43grams for a diff is pretty heavy for 25.5t spec motor to handle...With all plastic housings and a CF shaft the weight should be able to go down under 30grams...
bertrandsv87 is offline
Old 11-09-2020, 06:56 PM
  #15407
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Ah the resident slow expert has chimed in his thoughts.
perez62682 likes this.
Dan is offline
Old 11-11-2020, 10:08 AM
  #15408
Default F1 Tires on Black Carpet
Hey guys just getting back into F1 on carpet. I picked up a set of the CRC tires for my car. I know when I raced a few years back guys were glueing the sidewalls on the tires. Is this still the thing to do with new tires?
JoeRocket is offline
Old 11-11-2020, 10:11 AM
  #15409
Trader Rating: 18 (100%+)
Yes, the front outside sidewalls. I've read/heard you could also glue the front inside I'm extremely high traction situations but I've never had to so far.
Red141 is offline
Old 11-11-2020, 10:24 AM
  #15410
Ok cool. Thanks!
Old 11-15-2020, 01:07 AM
  #15411
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Can you use the Arrowmax 1/12th & 1/10th pan card setup station with an F1 (using appropriately sized bearings)?
Dan the Man is offline
Old 11-15-2020, 10:43 AM
  #15412
Why not. I use my Hudy 1/10 and 1/12th all the time.Some one with a 3D printer can make you the spacers needed. Most of the time I don't use them
BullFrog is offline
Old 11-17-2020, 02:22 PM
  #15413
GT CRUSING's Avatar
Finally, Tamiya have released the Halo from the Formula E car kit as an $11.68 stand alone part
I’m sure many F1 cars will end up having this particular halo. It’s just a shame that it has only come out as a stock white only part. I’m sure many would far prefer for it to be stock glossy black
kwkride likes this.
GT CRUSING is offline
Old 11-17-2020, 03:22 PM
  #15414
That's why they have paint.
BullFrog is offline
Old 11-18-2020, 04:20 AM
  #15415
Trader Rating: 88 (100%+)
Hmmmm, I wonder how hard this would be to 3D print...........
MUDVAYNE is offline
Old 11-18-2020, 08:26 AM
  #15416
GT CRUSING's Avatar
There's already several versions out that are 3d printed, it's just their quality does not match the tamiya one. When its 3d printed, it's harder to paint, more fragile and the surface finish isn't that great
Old 11-18-2020, 01:22 PM
  #15417
I could print this in a nylon material so it would be so fragile. The surface finish could be better by using thinner layers. I may give this a try
MUDVAYNE is offline
Old 11-18-2020, 06:36 PM
  #15418
Had many made and everyone paints them with no problem! It's only fragile when you crash alot.
MUDVAYNE likes this.
BullFrog is offline
Old 11-20-2020, 06:37 PM
  #15419
So i just picked up a X-ray X1’20 for fairly cheap. I couldn’t pass up the deal. And now i am curious what manufacture of front and rear wings are out there and available?
FXDXT916 is offline
Old 11-20-2020, 10:06 PM
  #15420
Mon-tech/ Xray--- they are the same only xrays adds a dollar.
BullFrog is offline
