Mugen MRX-4
Old 08-25-2005, 06:50 PM
  #631
TitaniumR's Avatar
Originally Posted by righthandeg6
I love my MRX4 I mean I just started driving it and it is absolutly the strongest car I have ever owned. But if I had to choose between a MRX3 and any of the cars made by the other companies I would choose the MRX3. Mugen quality is just in a class of its own.
Very strong yes. Interestingly, it's also underweight - good and bad.
TitaniumR is offline
Old 08-27-2005, 07:33 AM
  #632
racer x 1's Avatar
Trader Rating: 27 (100%+)
hey guys i drive a mrx3 and i was wondering if anyone knows if the mrx 4 rear floating body mount will fit the mrx 3?
racer x 1 is offline
Old 08-27-2005, 05:55 PM
  #633
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Hey guys the last time I ran my MRX4, the engine revved nice n high off the ground, but on the ground it ran quite a bit slow. Could this be that the adjuster nut is too tight? I had this problem with the R40 and the only way I got better acceleration was to loosen it. Aside from that maybe leaning out the low end would help a bit? At Floyd the car revved very weird like bbbwwwWAAAHHHBeewWWAAHHHbeeeWWAAHHH. I guess I need to take some time to really see whats up with it. Also, the plugs are a tiny bit smaller than the RB turbo plugs so maybe Nova's only will fit and run best with it. Soon as it gets going I can't wait to take it to the track.
HarKonnenD is offline
Old 08-28-2005, 10:37 PM
  #634
wad
wad's Avatar
Congratulations to RON CALANGI for winning the 1/8 scale REGIONALS at RAMS in san jose. Driving the MRX-4. He got the car only two weeks ago!!
Good job RON. Keep it up
wad is offline
Old 08-29-2005, 04:03 PM
  #635
cdelong's Avatar
Trader Rating: 12 (100%+)
what is the function of the cam lever on the lower front a-arm? i notice it moves the height of the arm. what position should it be in to start with, and when do i adjust it.
cdelong is offline
Old 08-29-2005, 04:33 PM
  #636
Slotmachine's Avatar
The lever you are refering to is used to achieve equal droop on both sides of the car without the swaybar hooked up, once you get them even then you can use the sway bar stops to adjust droop.
Slotmachine is offline
Old 08-29-2005, 04:47 PM
  #637
where do you guys buy parts and upgrades?
manokgt4 is offline
Old 08-29-2005, 05:28 PM
  #638
cdelong's Avatar
so-
1- do i start with the droop screws fully backed out?
2- does the sway bar have to be fully removed from the car or just fully extended to set the cam position? at full extension my sway bar is still engaged (although just barely).
thanks!
cdelong is offline
Old 08-29-2005, 06:09 PM
  #639
chemlab's Avatar
Default New Rear Upper Arm Set
Can anyone answer what will be accomplished by using the new upper arm set. I know that it will give more rear traction. It comes with two different set points can anyone give me more insight on how this new rear end works....Thanks....
chemlab is offline
Old 08-31-2005, 07:30 PM
  #640
chemlab's Avatar
Anybody
chemlab is offline
Old 08-31-2005, 11:24 PM
  #641
TitaniumR's Avatar
Originally Posted by chemlab
Anybody
Sorry for late reply Chemlab. See top of this page and the end of previous page. Carl Giordano did reply on this when I asked.
Old 09-01-2005, 04:59 PM
  #642
chemlab's Avatar
Thanks Thats what I get for not reading all posts in the forum...... I placed the upgrade on the car using the B version which will keep the car close to stock settings If I still have problems I will try the C. I wish this was out a long time ago we needed it for our track....
chemlab is offline
Old 09-01-2005, 06:24 PM
  #643
TitaniumR's Avatar
No problem.
Over here, I'm waiting for the upgrade to arrive. Let us know how your testing outcome is with this part. What do you mean by problems on your track?
Old 09-01-2005, 06:35 PM
  #644
chemlab's Avatar
Basically rear traction problems. We had too much front steering and not enough rear traction....The problem has been solved by placing Sand inside the sealer to create better traction.
chemlab is offline
Old 09-02-2005, 03:16 AM
  #645
i have four sets of fast tires left for the mrx-4. they are going for $37 a set including shipping and paypal fee. includes front and rear. email me at [email protected]. or call me at 305.807.9529
Joe Chaplow is offline
