Xray T3 2012
#2643
Battery positioning!!
Has anyone experimented with moving the weight of the lipo forward or back. The weight of a lipo is usually around 20g difference front to back so by positioning the plugs at the front should give a different weight bias to if they were positioned at the back.
Does anyone know how this will affect the car, should you always aim to get an equal weight bias front to back?
#2644
You don't need to aim for 50/50 weight bias front to rear, most of my setups have slightly more weight in the rear then the front.
#2647
My one looks and holds rock solid....
You can also apply some servo tape if you want but I couldnt get why do you think it may fail?
Cheers
Cheers
#2649
T3 2012
Really pleased with the performance and reliability of my 2012! Car is dialed on carpet with our club spec Sweep True Blue tires. I am Running the car virtually stock with the exception being the 50mm ecs shafts and the Side Piece Racing spool outdrives! My only real complaint is the $12.00 shock bladders that tear occasionally.
#2651
Using Tamiya Bladders& Xray Alloy shocks last couple of years without any problem ,Should We Change them time to time With New ones Despite They Still looks Brand new?
Cheers
Cheers
#2653
I guess 2mm chassis, centre servo holder and alloy steering arms = t3 2013
#2655
You guys are crazy if you think XRay is going to throw in $350 worth of hopups in the new kit.
The topdeck and chassis shapes will see slight changes. Maybe the servo mount will get thrown in. Perhaps the camber link plates will be lower with a wider range of adjustment. That's about it.
