Like Tree1Likes
Xray T3 2012
Old 05-29-2012, 04:43 PM
  #2611
Trader Rating: 38 (100%+)
What are the pros and cons of the adjustable pistons and do the pros outweigh the cons? Thanks.
or8ital is offline
Old 05-29-2012, 05:28 PM
  #2612
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
New Nikita V3 outdrives now available at www.sidepieceracing.com/products/nikita/. They feature a 90 degree offset to further reduce wear and tear on the drive line. The outdrives are designed for 50mm drive shafts, but might fit 52mm shafts depending upon arm spacing. The depth of the U cut is similar to the original manufacturing run.
hanulec is offline
Old 05-29-2012, 06:10 PM
  #2613
defcone's Avatar
Trader Rating: 15 (100%+)
Any chance you have a pic with a xray driveshaft sitting inside?
defcone is offline
Old 05-29-2012, 06:16 PM
  #2614
olhipster1's Avatar
Trader Rating: 102 (100%+)
adjustable pistons only pro is the ease of being able to change make a quick change to the shock oil flow. Thats it.
no other advantage...
they tend to get loose and change setting after crash/etc.
more parts inside the shock...etc.
always go with fixed pistons...no disadvantage...build it and leave it.
Xray shock are very good...when they are built correctly.
olhipster1 is offline
Old 05-29-2012, 06:17 PM
  #2615
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey Guy's,
I got to try out these Nikita Outdrives On my Xray T3. I was very impressed with how they worked and the Quality of the machining.
mike ivy is offline
Old 05-29-2012, 06:29 PM
  #2616
hanulec's Avatar
Pic of initial finishing Nikita V3 installed in Mike Ivy's XRay T3'11/12 with Spec-R drive shafts (equivalent to XRay 50mm)
hanulec is offline
Old 05-29-2012, 06:33 PM
  #2617
Thumbs up
Thank you. That's what I figured.
or8ital is offline
Old 05-29-2012, 06:38 PM
  #2618
MikeXray's Avatar
Trader Rating: 73 (100%+)
I tested the V3's in my car with 2.0/1.5mm spacing and there was plenty of clearance with 50mm ECS's (xray ones). They worked great, can't wait for my shiney set to get installed
Also added a "seis" fan this weekend.
MikeXray is offline
Old 05-29-2012, 06:39 PM
  #2619
defcone's Avatar
Did you try 52mm's?
defcone is offline
Old 05-29-2012, 06:50 PM
  #2620
MikeXray's Avatar
Originally Posted by defcone
Did you try 52mm's?
I don't have them, I never understood why anyone needed them other than that hagberg runs them so they must be better The SPR outdrives work well with 50's even up to 2.25mm spacing.
MikeXray is offline
Old 05-29-2012, 06:51 PM
  #2621
defcone's Avatar
I run them because they came with the kit and the cheap alternatives to esc's (Spec-r) are 52mm lol.
defcone is offline
Old 05-29-2012, 06:54 PM
  #2622
hanulec's Avatar
the picture i've included includes the SPEC-R -- which are like 50mm, not 52mm.
hanulec is offline
Old 05-29-2012, 07:18 PM
  #2623
NolanP's Avatar
Ummmm....Hanulec There's something missing....Top now huh? You selling your 2012?
NolanP is offline
Old 05-29-2012, 07:35 PM
  #2624
hanulec's Avatar
never owned a 2012. last XRay was a T3 (2010). i'm just filling a product gap -- good outdrives!
hanulec is offline
Old 05-29-2012, 07:53 PM
  #2625
defcone's Avatar
Any plans for a similar product for the gear diff? It seems like everytime I'm replacing that plastic bit, only half of it is used.
defcone is offline
