Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-09-2011 | 06:06 PM
  #1756
Chris Peralta's Avatar
Originally Posted by Muggydude
No, you SHOULD defend it!
All you have to say is:
"That's not true, Strike fuel works absolutely fine for break in. It doesn't matter if it has caster oil. The most important thing is keep it under 40,000 rpm etc etc. "
Not that hard. Every post you make does not have to have something negative in it.
Yes sir, mr. Moderator sir!!!
Chris Peralta is offline
Old 11-09-2011 | 06:18 PM
  #1757
kgombe's Avatar
Originally Posted by houston
boys good stuff
i have been able to take a number of engines apart that have been running team stryke( amongst other fuel brands ) and i will say without a doubt that it is not an "optimal" break in fuel as it has VERY LITTLE castor oil but on the same token odonnell which doesnt have much castor either doesnt seem to coat the piston/sleeve fit (compression seal) area as much as team stryke does . i have noticed that the team stryke leaves a build up on the piston and the sleeve where they meet to form a compression seal and unless running the engine above 230° range the "proprietary lubrication" oils sidewinder uses will for lack of a better term shellac on the surfaces of the piston/sleeve. i have also noticed a builduo of what looks like melted crayon on theintake throat of the crank weird
take it how you wish but castor is IMO a necessity when breaking in engines , i would recommend at lest a 6% castor blend , byrons race 3000 = 6% castor 5% synthetic blends , i am happy using this fuel for at least break in , not a bad idea to run all the time
i have tested some blue vp powermaster fuel and i can tell ya it is a great fuel also ( dont ask )
told ya that fuel is good stuff
kgombe is offline
Old 11-09-2011 | 06:53 PM
  #1758
houston's Avatar
Tech Prophet
This is about the nova engines and products
houston is offline
Old 11-09-2011 | 06:58 PM
  #1759
kgombe's Avatar
oooopssss
kgombe is offline
Old 11-09-2011 | 07:37 PM
  #1760
houston's Avatar
Tech Prophet
oooopssss
You have my number , we can discuss otp
houston is offline
Old 11-09-2011 | 08:43 PM
  #1761
vypr2002's Avatar
Originally Posted by ABN Hoosier
well.......I was told by about two dozen people I would be fine using the Stryke fuel for break in...
Just wondering what the optimal point would be to run this S&W fuel.
Don't use the S&W fuel until you have no metal pinch. To find this heat the engine up, by pre heating then running it on the track. Then remove the plug and see if it sticks or has pinch at tdc. If not then you are good to go with the S&W. Are you running trophyblend or trophyblend3?
3 has less of the synthetics, and is recommended to be used on the Nova engines. That's my 2 cents on the S&W fuel, as far as the rest of the shenanigans on this thread...................................... peralta is probably one of the most helpfull guys in our area, and the most knowledgable. Muggy has been helped A TON of times and has asked 4 billion questions on my local forum and has not learned a darn thing. Once again my 2 cents.
vypr2002 is offline
Old 11-09-2011 | 09:36 PM
  #1762
ABN Hoosier's Avatar
I will try the pinch test. Wasn't quite sure on how to test for that, thanks. I have a few gallons of this fuel. I guess it's just Trophy blend...
ABN Hoosier is offline
Old 11-09-2011 | 09:49 PM
  #1763
vypr2002's Avatar
Yep that's tb it's great stuff but if you are running nova then the three is what you want. Just do not use after run oil. You won't need it.
Any other s&w questions just pm me that way we don't jam up this thread
vypr2002 is offline
Old 11-10-2011 | 07:48 AM
  #1764
thanks
Old 11-12-2011 | 10:38 PM
  #1765
savagesam's Avatar
Default reply
Hi there guys here is the new Clockwork modified Novarossi P5XLT in my serpent truggy stretching its legs today in the car park at the track, tune was a little off but the power is crazy so I thought I would share this footage.
http://youtu.be/N2dvPoxGVqQ
savagesam is offline
Old 11-13-2011 | 02:52 AM
  #1766
Default novarossi
hi guys , can you tell me if the front ceramic bearing in novarossi 4btts has problems and must replased it soon? and if this is true maybe is better to take the 4btt with one ceramic
thank you
sotirisn12 is offline
Old 11-13-2011 | 08:19 AM
  #1767
houston's Avatar
Tech Prophet
thank you
I havent seen or heard of any issues with the ceramic front from novarossi
If anything I have noticed an even longer life out of the ceramic balls over the steel
Price is a little outrageous for the 17012 though
houston is offline
Old 11-13-2011 | 11:43 PM
  #1768
Lille-bror's Avatar
Default 4,5 5,0 and 5,5 mm venturies
Hi.
Where would it be possible to buy those small venturies? Could be a lot of fun trying them and see how the engine perform and how good my tuning skills are
I've heard Adam Drake uses 4,5 mm venturi from time to time. If he can...
OS makes 5,5 mm and they should fit a Novarossi carburator, right?
Lille-bror is offline
Old 11-14-2011 | 12:04 AM
  #1769
merdith6's Avatar
Default true
The Monty Pimped X7 I have had the ceramic balls put in front and rear, and let me honestly tell you, that motor spins smoother than any engine I've worked on, it's super silky. After a few gallons everything broke in and after I take it apart and clean and oil it, oh wow, it's perfection.
merdith6 is offline
Old 11-14-2011 | 04:04 AM
  #1770
Maximo's Avatar
myself I am not really into ceramic bearings.... IMO they typically fail sooner then steel and offer absolutely zero performance benefits....it kills me to see people saying ceramics help performance as they do absolutely nothing measurable or noticeable...IMO a whole bunch of hoopla over nothing tangible ! I have dyno and track tested ceramics many times over and my results were nothing noticeable...dyno didn't show any gains, and neither did any back to back track testing........that is my story and I am sticking to it,..bur hey, what do I know about engine performance !
Maximo is offline
