Like Tree5Likes
SC10 4x4 Thread
Old 11-06-2011 | 07:10 AM
  #10231
Cptn Cartwheel's Avatar
Originally Posted by Evil Genius jr.
What O-rings would you recommend? I tried using just on stock ring and it was much smoother but it was also very leaky.
Trackstar o-rings. Some guys use two, some use one and one stock X-ring. Some guys just unscrew the cartridge 1/16 to 1/18 of a turn. Too much squish on the stock rings and silicone makes them expand over time. The stock shock boots also cause a bind because theyre so tight to the shaft and cant breathe during compression and rebound. You can see them expand like a balloon during compression. You can remove the boots completely or use a hole punch like we do to our tires or you can just cut a slit in the boots up high toward the cartridge. They should be butter smooth after that.
Cptn Cartwheel is offline
Old 11-06-2011 | 07:13 AM
  #10232
Evil Genius jr.'s Avatar
Thanks! I had already vented the boots. One more question. Why are the trackstar O-rings $3 for 8 when the stock are $10 for 8? It doesn't make sense.
Evil Genius jr. is offline
Old 11-06-2011 | 07:26 AM
  #10233
CraigMBA's Avatar
Originally Posted by gatorage
sorry, i read the post but like to buy one from amain or tower.
Since they don't sell anything like that, you'll not be getting one.
CraigMBA is offline
Old 11-06-2011 | 07:33 AM
  #10234
CraigMBA's Avatar
Originally Posted by Vegatron75
The truck ran well though, I just hate having a truck that sounds bad. I'd rather it look like hell and sound good then the other way around.
Did you replace the outdrive o rings? Mine (in the rear) are the cause of the outdrive wobble, I'm certain. The front ones are tight as a drum.
Trackstar was testing some higher durometer o rings, but then it went quiet. Dunno if it didn't work or what.
CraigMBA is offline
Old 11-06-2011 | 07:58 AM
  #10235
MantisWorx's Avatar
i will go into details later but i am using Viton "X" rings on the dif cases with no flat washer and green slime. made it all last week through 4 days of racing and no leakage. i also eliminated the spider gear washers too, this combo freed up the difs and they are even smoother than before.
MantisWorx is offline
Old 11-06-2011 | 08:18 AM
  #10236
sugs's Avatar
Anyone notice anything?
Nice and clean.
sugs is offline
Old 11-06-2011 | 08:29 AM
  #10237
BryanAZ's Avatar
Thought I fixed my rear diff problem. I guess I didn't.
Went racing Sat., my rear diff had previously been making a clicking sound, while on power and turning.
I replaced all the internal gears and took it back out. SOunded good for a while and then started clicking again.
Pulled it apart and I can see the very edge of the sun gears is polished. I also noticed the lip at the top of the sun gear is actually touching the cross shaft. I also noticed the shelfs inside the diff are a little compressed. Probably effecting the placement of the diff shafts.
What the heck can I do? I tried some thicker shims on the cross shafts, but they're too thick. Can I use 1 thin and 1 thick on the same cross shaft?
Everything in the diff is new except the outdrives.
Really starting to bother me.
How are the brass bushings in the side of the gear case? Mine wallowed out and caused my diff to make noises and outdrives wobble.
BryanAZ is offline
Old 11-06-2011 | 08:31 AM
  #10238
BryanAZ's Avatar
I also had some bent dog bones, so that probably exacerbated wearing out the brass bushings.
BryanAZ is offline
Old 11-06-2011 | 08:36 AM
  #10239
Vegatron75's Avatar
Yeah, I changed em'
Vegatron75 is offline
Old 11-06-2011 | 08:38 AM
  #10240
Mizchief's Avatar
Originally Posted by ShortCourseOnly
I had a similar experience without the water. I had cogging and replaced the stator on the motor and it was fine. I would not expect the ESC to bet the issue. Now why the motor Stator had issue I don't know. I have been running the motor for a whole race series. Can you identify any high impact or high temp condition? I ran mine in a Jammin SCRT10 and for sure made a lot of chassis slaps and high power hits. Temps were always good. So I'm confident that the Tech service guys will help you out.
It's had it's share of hard landings, but nothing excessive, and nothing at the time of the failure that sticks out. Temps have been good so far and haven't broken 100deg on motor or esc.
Mizchief is offline
Old 11-06-2011 | 09:14 AM
  #10241
fastrc64's Avatar
you also might want to check the rotor if the epoxy gives out it will slip and sound like cogging.
the way to check it is take the gear cover off and put the truck on the ground and hold it in place and looking at the motor shaft under power it will look like it shudders in place
cause of this is over gearing it and causing too much heat on the rotor and brakes down the epoxy or trying to jump ur house
fastrc64 is offline
Old 11-06-2011 | 09:38 AM
  #10242
old&slow's Avatar
Default mud gaurds
Nice mud gaurds .How did you build em or where did they come from. I was thinking about some type of mudgaurd for the front to place behind front wheelss to keep the dirt out of inside of chaisis, I run indoor clayand shock boots so dont see a whole lot of dirt kicked up , but for you outdoor crews those look like the ticket
old&slow is offline
Old 11-06-2011 | 09:42 AM
  #10243
old&slow's Avatar
Default shock issues
Hey evil ,
I had same friction and leakage isues , read my post a bit back about clearancing the cartridge caps , and honing out the stock x rings a bit. The x rings will loosen up as you run them and become much smoother as you go , but i dont have patients to wait. Lots of greem slime , cartridges in the correct direction and you should be good to go. I also went to a softer bladder and it seemed to eliminate the big hit blow outs i got from the og firm as plastic bladders.
j
old&slow is offline
Old 11-06-2011 | 09:43 AM
  #10244
Thanks!
Do you happen to know what page your post is on? Its a long thread to look threw.
  #10245
MantisWorx's Avatar
RCShox Mutipoint ackerman bars! These are some preliminary pix of the ACK bar i will be testing this week. It is ballbearing supported and gives you three options for mounting the tie rods!
If testing goes well i will begin pre-orders at the end of this week.
