SC10 4x4 Thread
i know people have had problems with slippers. i have not had any problem with my truck(3 race on it)(i run my slipper all the way tight or lock as much as i can). but what i want to know is what part is everyone buying to fix it if it dose go out. or should i not worry about it if i run it tight like i do.
Please read the thread.
Im still having problems with the shocks binding. It seems to add about 10wt to the oil I am using, its very drastic. I tried removing the lower x-ring but all the oil leaked out over night
. Any ideas? Aftermarket rings? Thanks!
http://www.rctech.net/forum/9392323-post57.html
So, question is:
Does this sound like a common problem caused by water damage? I can probably get it fixed under warranty, but if it can really go tits up that easy I just don't see how I could depend on it for racing.
The motor and ESC are the Novak SC Pro combo with the 4.5 ballistic 550.
Does it sound like a Motor or ESC problem to you guys, and assuming I only replace either or, what you would recommend as an upgrade for the damaged component?
Thanks guys,
Thanks guys,
How many races on the truck? Are your shafts bent? Have you rebuilt them?
Sparkwraps posted on my "For Sale" thread how he did it, with pictures.
Thought I fixed my rear diff problem. I guess I didn't.
Went racing Sat., my rear diff had previously been making a clicking sound, while on power and turning.
I replaced all the internal gears and took it back out. SOunded good for a while and then started clicking again.
Pulled it apart and I can see the very edge of the sun gears is polished. I also noticed the lip at the top of the sun gear is actually touching the cross shaft. I also noticed the shelfs inside the diff are a little compressed. Probably effecting the placement of the diff shafts.
What the heck can I do? I tried some thicker shims on the cross shafts, but they're too thick. Can I use 1 thin and 1 thick on the same cross shaft?
Everything in the diff is new except the outdrives.
Really starting to bother me.
The truck ran well though, I just hate having a truck that sounds bad. I'd rather it look like hell and sound good then the other way around.
5Likes
