Like Tree5Likes
SC10 4x4 Thread
Old 11-07-2011 | 12:03 PM
  #10366
Wild Cherry's Avatar
Tech Legend
Originally Posted by ShortCourseOnly
I plan to stick with the slipper as well.
I will try your design, Wild Cherry. I'm getting the pushrod from the link above. I will post a photo once I try it.
I ground down the trans brace mount just bit to keep it even , hardest part is you will have to remove the ft clip & servo to install a lock nut under the ft stud...
best of luck
Wild Cherry is offline
Old 11-07-2011 | 12:13 PM
  #10367
the_freak's Avatar
Originally Posted by Wild Cherry
If you ask me the arrow shaft looks so ugly and out of place ....
Not for me ....
Everyone copy me !!!!
I was the first to tell you guys
how to make a chassis brace in the first place .....
if i look at this right i got to remove 1 bolt in front and 1 in the rear and replace them whit 2 longer onec isent that all ??
the_freak is offline
Old 11-07-2011 | 12:15 PM
  #10368
ShortCourseOnly's Avatar
best of luck
I have to tear the front down anyway to replace the servo. Now is the time to do it for me.
ShortCourseOnly is offline
Old 11-07-2011 | 12:21 PM
  #10369
Tech Legend
will need a lock nut under the ft stud to help keep it tight & strong.
Old 11-07-2011 | 12:25 PM
  #10370
the_freak's Avatar
in the front end right??
jut a normal 3mm lock nut and some spacers u got in blue ( i like that )
and 2 loger 3mm bolts thats it and the puch rod ??
what is a FT stud???
Old 11-07-2011 | 12:27 PM
  #10371
Tech Legend
ft stud = screw holding the ft brace
This screw will need a lock nut ...
Old 11-07-2011 | 12:29 PM
  #10372
So you installed it prior to installation of the front plate correct. This works OK for me.
Old 11-07-2011 | 12:33 PM
  #10373
Tech Legend
Default 125m Ti rod chassis brace
right , using a 125m Ti rod
  #10374
I ordered a pushrod set. Wish I could hand you one Freak but I'm not in Denmark. Dette er en masse sjov.
Old 11-07-2011 | 12:34 PM
  #10375
I think I order the longer rods. Looks like there is enough room I hope. The spec I read is 137mm End-to-End. That may be a 125mm rod itself.
Old 11-07-2011 | 12:40 PM
  #10376
the_freak's Avatar
ggg nice not right in grama but i get it
im going to give this a gowe some time during this winter but going to order the puch rod and the rest for it
can u let me know what u think off this befor i take my truck apart
Old 11-07-2011 | 12:51 PM
  #10377
[QUOTE=MantisWorx;9880053]you dont want the tall ones, they make the truck handle horrible.
Mantis,,
I went from 5000 nano-tech saddles to IP 6000 packs, the 6000mah packs are about 6mm taller, and heavier, run in the same place at the front, the truck did seem harder to drive after that, I put it down to track conditions, we run on a large outdoor bumpy loose track here.
I'm very interested in your findings.
Cheers
Ross.
RossNZ is offline
  #10378
Cameron Kellogg's Avatar
no pin , like the slipper better...
OK then I am not crazy. I am faster around PRCR with the slipper and the 19th over the pin mod set up.
Cameron Kellogg is offline
Old 11-07-2011 | 01:27 PM
  #10379
Tech Legend
I think there is'nt much difference between the two , but the slipper seems to keep the pull a bit more predictable ....
Old 11-07-2011 | 01:29 PM
  #10380
Chad Smith's Avatar
Ok thanks for all the replies. So basically I attached it on the top of the rear gear box and front gear box with a screw and locknut on both the screws? Is everyone using shock ends on the end of the brace?
Chad Smith is offline
