Like Tree5Likes
SC10 4x4 Thread
Old 11-07-2011 | 10:51 AM
  #10351
ShortCourseOnly's Avatar
Originally Posted by Wild Cherry
If you ask me the arrow shaft looks so ugly and out of place ....
Not for me ....
Everyone copy me !!!!
I was the first to tell you guys
how to make a chassis brace in the first place .....
While this is a nice looking solution I don't think it will help as much as the others. I am an engineer and it is clear that this will not stop most of the flex. The brace needs to connect as close to the input shafts as possible to control belt tension. Sure does look good though.
ShortCourseOnly is offline
Old 11-07-2011 | 10:52 AM
  #10352
cpt_RedBeard's Avatar
Originally Posted by SS LS1
I also considered tying into the shock towers but scrapped that idea as I want the towers to be able to flex independently in a crash w/o directly affecting the distance between the gearboxes.
I tried a brace that went from tower to tower... it split the carbon fiber rod into about 6 pieces. I think the leverage from tower to tower is too much.
cpt_RedBeard is offline
Old 11-07-2011 | 10:55 AM
  #10353
MantisWorx's Avatar
Originally Posted by ilanstylz
For those using the saddle pack mods, whats the biggest size saddles you can use? H/W/L?? Thanks
you dont want the tall ones, they make the truck handle horrible.
Jay, its crazy how much a simple adjustment makes, i dropped 2 seconds give or take along with the camber decrease and STRC hubs!!
MantisWorx is offline
Old 11-07-2011 | 11:32 AM
  #10354
Is this guard just for bashing or ? What is the purpose, to keep dirt from getting on the arms and bearings?
hotrodhomi is offline
Old 11-07-2011 | 11:39 AM
  #10355
Wild Cherry's Avatar
Tech Legend
I'm the guy that first knew & posted about the flex problem with the belt.
Ti rod does work just as well as the other's , yes it can still flex just a little , not enough for the belt to get any excess slack however ....
Wild Cherry is offline
Old 11-07-2011 | 11:42 AM
  #10356
I'm the guy that first knew & posted about the flex problem with belt.
Ti rod does work just as well as the other's , yes it can still flex just a little , and that whats makes it more even betta in my opinion....
So would you say that the flex is reduced enough so you can loosen the belt to reduce drag? If yes then maybe I need to consider this. Some flex is good I agree.
What are your tensioner settings and pulley sizes?
Old 11-07-2011 | 11:45 AM
  #10357
Tech Legend
Only flexes a bit more than the shaft and I don't recommend loosening the belt for either braces ....
Use the factory tension settings
  #10358
To me this guard it to reduce the load of dirt that fills the shocks and halfshafts. This can happen a lot on loomy tracks. I am moving to a place that has more loomy tracks so I hope to pick up some of these ASAP!!!
Old 11-07-2011 | 11:47 AM
  #10359
OK. Are you using the 20t pulleys front and rear? Are you on the middle setting or higher?
What I do like about your design is that it is simply a Revo turnbuckle or push rod. That is cool!
What is the part number?
Old 11-07-2011 | 11:53 AM
  #10360
Tech Legend
using 20T in rear & 19T on the ft
Old 11-07-2011 | 11:55 AM
  #10361
So the rod Wild Cherry is using looks like a Revo Push Rod. Cherry is it this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXHFV9&P=Z
  #10362
Cameron Kellogg's Avatar
Are you still running the pin mod with that? I like that set-up but not with the pin mod.
Cameron Kellogg is offline
Old 11-07-2011 | 11:57 AM
  #10363
Tech Legend
no pin , like the slipper better...
Old 11-07-2011 | 11:59 AM
  #10364
I plan to stick with the slipper as well.
I will try your design, Wild Cherry. I'm getting the pushrod from the link above. I will post a photo once I try it.
Old 11-07-2011 | 12:00 PM
  #10365
SS LS1's Avatar
What deg rear STRC hubs did you install? What deg are the stock AE ones anyway, 0°?
SS LS1 is offline
