Like Tree5Likes
SC10 4x4 Thread
Old 10-28-2011 | 08:00 PM
  #9706
CoyoteSlash's Avatar
Originally Posted by dgrobe2112
for those guys asking about the diffs.. i know someone said it was 6 screws.. that is quite simply not the case..
here is what i did.. made it very simple to access the diffs..
1. Take of the bumper.. (4) screws..
2. under the bumper.. there is 2 screws that screw into the case..
3. take off the 5.5mm nuts that hold the shocks to the tower (makes moving tower easier)
4. there are (6) screws to take off, (4) front facing, and (2) vertical, this will allow the shock tower to fall out of place. i even popped off the captured ends, so the drive shafts are out of the way (helped with reinstalling diff) use the 5.5 nut driver, to press the ballends back on.
5. take off the clicker cover, and remove the clicker/slipper assy
6. (3) long diff screws that hold the diff together.. be sure to not lose the washers that are used here.
with the tower folded foward, the diff should come straight up. allready be apart. then of course reverse the build.
Sofar this has been the easiest thing to do without having to tear the whole front end apart. didnt take very long, less than 15mins i believe. also.. i have a small electric drill to pull the screws.. may take longer if you dont have this. also.. i do have swaybars installed.. and they do not need to be removed for this.. the tower simply folds, and rotates on the swaybar..
What I said was in efect to 6 screws to take the whole back end off after the bumper. (the bumper is self explainatory that it has to come off)
6 screws removed the entire rear end, A-arms, CVA's and tower. Then it's a simple removal of the diff. I thought I worded all of it well enough.
CoyoteSlash is offline
Old 10-28-2011 | 08:08 PM
  #9707
Divey's Avatar
Got the basket today. Super fast shipping and the finish looks really good. Fit was perfect as well. Props to MTK for a fantastic part. It's dark now so I can't truly test it but I will run it in my driveway real quick. I should be able to feel a difference right away. Will report back tomorrow and I am "pinned".
Also I have seen some people go with a lighter diff fluid in the front, what affect does this have o the truck. I am running 30k in the front and 5k in the rear.
Terry
Divey is offline
Old 10-28-2011 | 08:58 PM
  #9708
fastrc64's Avatar
Originally Posted by kghills
usually in the 7-8min range but sometimes as long as 10 minutes. I will post back after this weekend the time and mah used. I am curious how it will last also.
Keith.
you will dump with that 4000
fastrc64 is offline
Old 10-28-2011 | 09:05 PM
  #9709
fastrc64's Avatar
Terry
if your pinned the 30,000 fluid will make ur truck push bad. you are going to have to go lighter for sure
fastrc64 is offline
Old 10-28-2011 | 09:12 PM
  #9710
T-BirdJunkie's Avatar
Depends, ThunderbirdJunkie has gotten 20 minutes out of a 5000 with a 1410.
T-BirdJunkie is offline
Old 10-28-2011 | 09:20 PM
  #9711
CraigMBA's Avatar
Keith.
I think you'll be okay on time. But for the life of me, I can't imagine how having the battery in one corner and the motor in the other corner won't give the chassis 150-200 grams of wedge. Which is fine - if you are running oval.
Having 50/50 front-rear and left-right isn't very useful if you have a bunch of wedge in the chassis to get there.
I would suggest you try putting the speed control opposite of the motor, and the battery in the middle.
CraigMBA is offline
Old 10-29-2011 | 12:40 AM
  #9712
BLbound's Avatar
I ran for the first time in a few months tonight at the Hemet raceway. It's a very low key outdoor track & everyone is there for fun & competition. I ended up qualifying 3rd & finished 2nd. Most racers there had losi trucks...now that I think about it I think I was the lone AE truck! I think the pin mod would have been beneficial but not a "must" for this track. I didn't have any trouble clearing jumps & my truck was as fast as everyone else. What I did need is a outdoor track set up! I mostly run indoor, so when it came to the main I had gone back to blue springs in the rear & all 4 shocks in the middle hole on the towers. I had a good time, it was nice to get out & race & take a break from changing poopoo diapers!
BLbound is offline
Old 10-29-2011 | 12:46 AM
  #9713
TEAM-AE-4-EVER's Avatar
Wow! This thread sure moves a long in a hurry... tough to keep up when projects and work get you swamped!
Was hoping for some advise and tips... I scored a Tekin Pro4 4600 a few weeks back along with the MTK clutch Basket and the 3 Garodisk set from Mantisworx.
I finally found the time to install everything and for those with the same or a similar set-up, I was wondering what pinion to use with the 32 pitch Spur? Was leaning toward a 13T... I usually run on an mid to large outdoor track which does accommodate 1/8th Scale racing... big jumps and all. Its loose dirt and quite dusty when dry. Except for the tires, I also emulated what I could from the Ryans set-up posted on AE's website for the Reedy Truck Race of Champions.
Lastly, when installing the 3 Garodiscs with the Clutch Basket for the first time, should the nut be flush on the idler gear shaft or tightened further? I know some recommend "pinning", but I'm not ready for that yet and want to see how this goes before maybe trying that and experiencing the difference.
Any thoughts and recommendations would definitely be very much appreciated! Thanks!
TEAM-AE-4-EVER is offline
Old 10-29-2011 | 06:41 AM
  #9714
SourDieselX's Avatar
recommendation, turn that motor waaaaaaaay down, for our trucks it's to much, our trucks are far to light for that motor, i have the 4600 and it just flies.
SourDieselX is offline
Old 10-29-2011 | 07:05 AM
  #9715
I wood like the web site to MTK so i can order the basket for myself and does he sell the slipper pads too or do i have to go else where?
special_k is offline
Old 10-29-2011 | 07:09 AM
  #9716
tony montana's Avatar
+1
tony montana is offline
Old 10-29-2011 | 07:18 AM
  #9717
BlueGlowBoy's Avatar
Originally Posted by vr6cj
Here's my layout if it helps.
Only 5 blades on the fan leaves room for big rocks to get caught inside....most ESC fans have 8-13 blades....just as much airflow, smaller space for stuff to get caught.
I took some wire mesh from a broken screen door, cut it to the size of my fan, and used the fan screws to hold it on. Haven't had ANY issue with chipped fan blades since, and temps did not change.
If your fan is not dieing because of dirt, but is in fact dieing from hard landings, then try a fan from LRP or Tekin (the RX8 fan lasts wonderfully but the plug is a little odd, you might have to rewire it yourself)
BlueGlowBoy is offline
Old 10-29-2011 | 07:22 AM
  #9718
Originally Posted by Chad Smith
Anyone see this yet?
http://www.rccaraction.com/blog/2011...ated-sc10-4x4/
I guess someone listened to everyone about getting pushed around by the heavy Losi lol.
Anyone else notice the battery foam they have zip tied to the front of the belt tunnel? What the heck is that for?
Old 10-29-2011 | 07:24 AM
  #9719
Mac The Knife's Avatar
http://gearrings.weebly.com/rc-racing-stuff.html
Here's the link, And no, I don't sell the clutchpads, since most people have extra pads,,, and there are different ways of setting up the clutch.
Thanks!!
Mac The Knife is offline
Old 10-29-2011 | 07:25 AM
  #9720
symmetricon's Avatar
this
http://rcshox.com/shoxshop/catalog/i...ddf7bb8903e8f7
and this
You will have all the clutch tuning you could ever need, and will never have to buy another clutch part.
I just bought a ton of hop ups, tires&hazard rim, and spring, and noticed when I installed the yellow springs, they no longer rub the shock body I was so peaved when I got the ft shcok bodys, only to have the springs rub on them, well thats a thing of the past
symmetricon is offline
