SC10 4x4 Thread
#9616
i have been testing the outerwears dirt shroud for quit some time and it works great i have the plastic one also but the outerwears is way better and keeps out more dirt and mud
#9617
I have my ends screwed three turns out on the back, 4ish mm of limiting pretty much solves the outdrive issue, so I cut mine 7ish mm.
#9618
in the pictures you can see my slipper nut is only about half way on the shaft , also you can see my outerwears dirt shroud on my truck it allows maximum air flow . i don't even use fans on my ESC or Motor
here is the ultimate protection from dirt mud and water you can get your for sc10 4x4 about $35 @ outerwears inc i love mine does a great job and looks really great as well .
#9619
Just cut the appropriate length of fuel tubing. Unscrew the rod end, slide it on. Now you're protecting your outdrives AND getting a bit of "second stage damping" soft bottoming on which ever end your doing.
7mm seems a lot.
#9621
This problem can be overcome by shimming the inside of the diff on the black piece.
#9622
I have also increased my down travel by 3mm. Works out a lot better for me especially in the bumpy area. I think the fuel tubing idea will work for me. I have tons of it left from when I ran nitro. Thanks
Terry
Terry
#9624
#9625
Has anyone tried running the 306 Reedy 4000mah 60c lipo all the way forward as apossed to converting to saddle packs? Seems that it would offset a 540 motor almost perfectly. Or maybe mount it across the front offset to the right side.
I think I will try it out.
Keith.
Keith.
#9626
yes, there is too much up travel in the shocks. If you compress the shock all the way by hand and turn the cva, the cva will bind up with the diff outdrive. Hence the need to limit the shcoks. as a side not, this is only apparent when the shock boots are off.
#9627
Hey guys,
What would be the best universal motor that I'll be able to gear for technical indoor tracks and medium sized outdoor clay track. I will be using it with a mamba max esc. Please help me out as I'm new to the 4x4 SC scene.
Thanks,
Dan
Thanks,
Dan
#9628
Castle 1410 and 1415, Novak ballistic, Tekins and Vipers are all popular. Castles aren't sensored though.
#9630
Letter to Associated:
I don’t know about others who have called Team Associated lately and who they been talking to, but after having been a loyal Team Associated vehicle owner of one sort or another over the past fifteen years I have to sayI become increasingly dissatisfied with your products, in particular the SC104x4.
I find it hard to believe that when I called today seeking warranty support for the substandard components/parts that I (and plenty of others)have had to contend with, I spoke with Chris in product support and I explained how the slipper assembly overheated, essentially melting things like the slipper pad to the spur and heating the spring to the point it became discolored and useless (despite being “locked down”). He informed me would only be replacing few specific components ( implying I should happy with that) and that the “best solution” was to purchase the ClutchBasket. Really? I have no doubt it works but should I have to be directed to a third party manufacturer to resolve an issue with your product design? You should at least be willing to replace the slipper components when it’s been clearly identified as a week point in the drivetrain. I also mentioned the “bent”front/rear A arms and I was informed that these would not be replaced under warranty because in his opinion this was caused by the vehicle sitting too long on its wheels… and they’re made “soft”on purpose to avoid breakage.
Again…really? So just like the substandard slipper design I now have to consider paying for RPM A arms (or buy AE’s) to compensate for poorly manufactured/designed AE A arms. All of this after I received the truck minus the entire shock bag and having to wait months for replacements to be sent.
I want to believe this is an isolated experience and that if management knew about this they would attempt to make it right but I’m not entirely convinced. I hope others have avoided these sort of problems and havereceived better service and support but I know this has certainly discouraged me from commenting positively about my Team Associated experience.
Again…really? So just like the substandard slipper design I now have to consider paying for RPM A arms (or buy AE’s) to compensate for poorly manufactured/designed AE A arms. All of this after I received the truck minus the entire shock bag and having to wait months for replacements to be sent.I want to believe this is an isolated experience and that if management knew about this they would attempt to make it right but I’m not entirely convinced. I hope others have avoided these sort of problems and havereceived better service and support but I know this has certainly discouraged me from commenting positively about my Team Associated experience.
5Likes
im getting the ower tray for my truck i hope it will work for keeping dirt out and at the same time not make my esc to hot
No more bent front cva's also
