Like Tree5Likes
SC10 4x4 Thread
Old 10-29-2011 | 10:49 PM
  #9766
CoyoteSlash's Avatar
Originally Posted by T-BirdJunkie
ThunderbirdJunkie had his shaft pinned. The ladies loved it, but it dribbled out the sides when he peed.
That's awesome of you, CS. ThunderbirdJunkie may send you his spare rear topshaft just in case he comes across a screaming deal on another 4w SC10 he can't turn down.
I knew i'd get one of those responses. And yeah. It gives me something to do. Otherwise I pull my Sc10 down and tear it apart for no reason.
CoyoteSlash is offline
Old 10-29-2011 | 11:04 PM
  #9767
Vegatron75's Avatar
RX8 won't fit, unless you hacked it up a little. MMP barely fits.
Vegatron75 is offline
Old 10-29-2011 | 11:29 PM
  #9768
BLbound's Avatar
Thanks Vegatron...I was hoping you wouldn't say that .
BLbound is offline
Old 10-29-2011 | 11:39 PM
  #9769
JS's Avatar
JS
BLBound and others - Here are some pics of the RX8 under the belt.
Had to dremel the cage and the rear chassis brace to clear the RX8's fins and rear solder post.
Paired the RX8 with a 1410 and running inline saddle packs. Chassis has 3.5oz of added weight.
Don't mind the positioning of the packs. I messed up a bit on lining up the countersunk holes - lol.
Car weight - no body
FL 580g - FR 581g
RL 709g - RR 707g
Ran the Saddles before up front (Left/Right).
Balance was nowhere this close.
btw - running the pin mod, clutch basket (HT/Reg/HT) and overdrive front pulley - Night and day difference
Attached Thumbnails SC10 4x4 Thread-imag3274.jpg   SC10 4x4 Thread-imag3263.jpg
JS is offline
Old 10-29-2011 | 11:44 PM
  #9770
FL 580g - FR 581g
RL 709g - RR 707g
The symmetry those two saddles lack are going to cost you in the standings... tsk tsk.
Old 10-29-2011 | 11:48 PM
  #9771
JS's Avatar
JS
I did a bunch of holes on that chassis for inline and side by side setup to test which will work best for me.
I think this is the best setup. I will end up getting another center chassis and redo the inline holes - hope to get it lined up properly this time
JS is offline
Old 10-29-2011 | 11:53 PM
  #9772
I have 8 stick packs. There's no way i'm going to venture into Saddles for 1 truck. If I had a b4 i'd consider it. Benefit or not, i'll figure it out.
The rig looks good though. I like using the pockets on the side of the chassis as weight "pouches". :P
Old 10-30-2011 | 12:06 AM
  #9773
JS's Avatar
JS
I had 3 Gens ace that I used for my 2wd SC and SC10 4x4. Two puffed. No more Gens ace for me.
I figured I can use the Saddles lined up like a stick pack in my 2wd SC if needed.
The Nano-Tech's have not given me any problems. I have at least 20 cycles on 2 sets. Much better performance with my RX8/1410.
Yup - the weight pouches are great. You can take it out anytime for quick adjustments and not mess around with the doublesided tape.
JS is offline
Old 10-30-2011 | 12:13 AM
  #9774
I work at a LHS that only carries good stuff. We refuse to carry Shitty Batteries, and product. It's just how the Boss is. Which means prices aren't always agreeable to these other people. But we shrug it off. I never understand why you spend so much money on Aluminum, Graphite, ceramic bearings... Motors, Esc's, rediculously-pointlessly fast servos.. etc. And you cheap out on the only thing that makes any of it worth while: The batteries and Charger.
Man. LHS employment is a blessing and a curse.
Old 10-30-2011 | 12:15 AM
  #9775
BLbound's Avatar
Cool...thanks for showing off your set up! So I'm guessing there's no need for the fan with a 1/8 speedo? I understand that you had to take it off to fit under the belt cover. Now at least I know it's possible.
FL 580g - FR 581g
RL 709g - RR 707g
BLbound is offline
Old 10-30-2011 | 12:58 AM
  #9776
JS's Avatar
JS
I never used the fan on the RX8.
It didn't matter how I geared the 1410.
Temps on the RX8 would never go over 135.
I will upgrade to a Pro4-4000kv soon.
I hope the temps on the RX8 stays around 140~
JS is offline
Old 10-30-2011 | 01:27 AM
  #9777
the_freak's Avatar
Originally Posted by ShortCourseOnly
I finally got my SC10 4x4 together and raced at Washtenaw RC Raceway. All I can say is wow. I do like this truck. thanks to Krio for some set-up advise and to all on this thread. I did not have a clutch basket but I did use Garodisks from RCshox.
After all the talk on here about the slipper I assumed that I would be battling slipper issues all day. After some practice and the first heat I torn the slipper down and noticed that the Front slipper was wearing near the shaft. My thrust bushing was protruding a little past the slipper plate such that the Garodisk was not contacting. I probably had very little front wheel drive.
So I removed the Garodisk from the Front slipper and replaced it with a HD pad. This solved my problem and I was getting much better punch. I do not check the garodisk yet on this I well check.
I'm not sure I will get a clutch basket since the Garodisks work so well with my 4.5 Ballistic 550.
howe did ur motor do??
i mean whit temps and speed what pinion size did u go whit??
the_freak is offline
Old 10-30-2011 | 01:33 AM
  #9778
BLbound's Avatar
Very cool, thanks for letting me know. I'm eventually going to go with the nano tech saddle packs too.
BLbound is offline
Old 10-30-2011 | 01:48 AM
  #9779
JS's Avatar
JS
JS is offline
Old 10-30-2011 | 02:56 AM
  #9780
the_freak's Avatar
ok this is maybe a dump question
but can the novak havoc pro esc run the tekin pro4 4600kv motor sensor off course ???
