RC10B4.1 FT/WC
Old 10-09-2011 | 09:48 PM
  #6391
tmail55's Avatar
Originally Posted by slammin1984
I have a t4.1 and I just recently purchased some rpm wheels. they are the revolver and bully style. anyway, i glued tires and mounted them. the fronts hit the a arm when i turn the wheel all the way. I have a dx3s and i put the travel down to 65% before it stopped rubbing the a arm. I tryed spacing the wheels but when I put shims in it the wheel locks up and you cant spin the wheel. when I loosen the axle nut enough to spin the wheel the wheel itself becomes wobbly. this sux because i just spent over $100 on wheels and tires. has anyone else run into this and if so what is the fix?!?!?!?!
I see you posted your ? on the "official" thread. and
racer1812 has the 1st place I would look for the problem.
T-BirdJunkie that is a good ?
Wonder IF the rims aren't the ones for a AE 2wd truck, had a set for a Losi xxxt the didn't fit well.
My GT2 and T4 the rims rub on the hub link, adjusted them as T-BirdJunkie stated to limit the amount of rub..
tmail55 is offline
Old 10-10-2011 | 08:51 AM
  #6392
Jmuck69's Avatar
Default +8mm chassis
It's official!
http://www.teamassociated.com/news/l...%2B8mm_Chassis
Jmuck69 is offline
  #6393
Matt Trimmings's Avatar
I dont believe that RPM ever made T4 wheels. Looking on their website it the descriptions are for associated wheel with either a 1/4" or 3/16" axle. That is how they were advertised for the t2 and t3 trucks. I couldnt find anything that stated they offered them for the t4 on the rpm site.
Matt Trimmings is offline
Old 10-10-2011 | 08:58 AM
  #6394
racer1812's Avatar
Super Moderator
Originally Posted by Matt Trimmings
I dont believe that RPM ever made T4 wheels. Looking on their website it the descriptions are for associated wheel with either a 1/4" or 3/16" axle. That is how they were advertised for the t2 and t3 trucks. I couldnt find anything that stated they offered them for the t4. The only wheels made to fit the t4 will be the ones by Associated or JConcepts.
http://www3.towerhobbies.com/cgi-bin...?&I=LXXLF6&P=7
racer1812 is offline
Old 10-10-2011 | 09:00 AM
  #6395
Originally Posted by air8
Exactly what I did. Filled shock body. Oil in shock cap. No bleed screw in cap. Put cap on and oil pushes out the bleed hole. Then as I compress the shaft I put the bleed screw in just before full compression so air can't enter. Cycle the shaft about 10-15 times and watch it retract into the body. Sometimes part way in, sometimes most of the way in. IDK.
As Wild Cherry recommended...repeat the bleed process once more. Do all that you stated and work the shaft up and down about 10-15 times and then compress the shaft in while backing the bleed screw off. The excess oil will bleed out, replace screw and you should be done.
Old 10-10-2011 | 09:01 AM
  #6396
purpurite's Avatar
Can anyone out there give me a thickness measurement on the B4 rear axle drive pin spacer (ASC9608)?
TIA!
doug
purpurite is offline
  #6397
Well now we need to know whether or not he bought the actual t4 wheels...and maybe rpm can update their site now
Old 10-10-2011 | 09:05 AM
  #6398
racer1812's Avatar
Super Moderator
I got my first T4 off e-bay and it cam with chrome RPM wheels and worked just fine. So yes the big question is if he has the right (AE) wheels, or if any of our other suggestions have fixed the issue...$.02
Old 10-10-2011 | 10:32 AM
  #6399
916bdogg's Avatar
Default AE +8mm ..
It's coming this month Boys . Put the Saws away !
916bdogg is offline
Old 10-10-2011 | 10:34 AM
  #6400
Led Finger's Avatar
Default hackin
" put the saws away "
Led Finger is offline
Old 10-10-2011 | 10:35 AM
  #6401
idrummerboy13's Avatar
Originally Posted by Jmuck69
WOOO PARTAY! lol now i should break mine, lol jk im just buying the battery strap and maybe the just the chassis just so it looks cleaner so sweet
idrummerboy13 is offline
Old 10-10-2011 | 10:38 AM
  #6402
Wild Cherry's Avatar
Hoping to see for the whole package.....
the
WORLDS EDITION
That
is....
Wild Cherry is offline
Old 10-10-2011 | 10:53 AM
  #6403
Timmahhh's Avatar
Looking forward to the long chassis.
Are you guys adding a lot of weight to the t4's? With about the same amount of sprung weight but much more unsprung weight, the truck seems a little bouncy compared to the buggy. I'm trying to decide if more weight or less dampening and spring are the way to go. I run my buggy pretty light (usually around an ounce of weight) but it seems like the truck could use quite a bit more.
When adding a lot of weight, what's the cleanest way to do it? Lead squares keep coming out of my rear triangles, and weight in the battery tray limits battery locations. Weigh behind my lowpro servo has worked out well up front, but the rear locations are limited.
Timmahhh is offline
Old 10-10-2011 | 11:03 AM
  #6404
air8's Avatar
Ok. Thanx Matt and Wild Cherry. I'll give it another shot.
air8 is offline
Old 10-10-2011 | 11:19 AM
  #6405
Oso Negro's Avatar
Thumbs up
the
WORLDS EDITION
That
is....
Me too....
Except they'd have to package it with Kyosho Springs!!!!
Oso Negro is offline
