MTX 5
#1036
For a bumpy low/medium traction track, the stock 1.1mm 1 hole pistons with 600 oil just did not work for me, so 2 hole pistons for me, though someone else at the track said they would try the Mugen 1.3mm 1 hole pistons.
#1037
Je, je si Papo, ya me di cuenta.... es que con los sistemas anteriores, sólo gatillando el freno, se bloqueaban las ruedas... Claro, se bloqueban cuando eran nuevos, pero en la pista, ni bien se calentaban un poco, los frenos se hacían humo.... je,je
#1039
Danjoy25,
I recommend you use the rear diffs of the nt1, they go perfect... for the front, use originals of carbon.. I lost a run using rear capricorn diffs in my nt1. Now, in my mtx5, I use rear diffs xray nt1.
Use rear carbon diffs for semis and finals.....
Regards..
Regards..
#1040
Papo, tengan mucho cuidado con el desgaste de los diferenciales de carbono traseros.... ya vieron lo que me sucedió en la final en machala...
Los diferenciales metálicos de xray nt1 van perfecto.
Saludos.
Saludos.
#1042
ya me lo veo venir
se me asen mierda el engranaje en un momento importante del dia
#1043
Sorry, yes moved in the top shock mounts one hole, but I think just the drilled holes created what I wanted, so I could move them back out one hole again.
#1044
#1046
gracias!!!
#1048
Maybe they should start writing in chinese , or russian , this way they can feel smart, or is it that they can't speak English , refuse to conform to the thread agreements or any sensible form of common communication !!! They will probably start writing in English in all the Spanish forums, just to let people know they can say a few English words ! That should tell the Moderators how "smart" a few can be, and that they should enforce a common language, just so it doesn't become a culture clash here !!! It is also profoundly disrespectful to continue writing in another language in the obviously English forums, and I think it is their intent to create controversy in an otherwise peaceful community !!!! Moderators should put a stop to this before it worsens !!! Stop forcing the Spanish Language down our throats, and go back home !!!
#1049
Though I'm not about to say it would work for everyone, just that I like a fairly soft setup.
#1050
Might try alloy gears
