Old 02-22-2012, 12:46 AM   #1786
Originally Posted by djiewie View Post
Thats real good for a stock built kit. Mine does aproxx 1595 gr. with lightweight parts. I put 100 grams on the batt tray to get the weight up. But the new serpent 747 will be lighter this year.
the servo side on the mugen is the lightest side. The battery is on the left side with the engine hanging off towards the left side, and the pipe hangs out a fair way out on left side also, so you need to add weight to the right side to even it out.
the MTX5 has optional titanium screws and pivot balls available to save weight, but for santioned racing i would need to add this wieght back onto the car somewhere.
You can add weight under the tank and in front of the engine, but i have a suspicion that the weights under the tank will affect the chassis' flex. the weights go screwed on as two plates and would take away flex in a similar way as a brass tray would eliminate flex on an NT1 or the capricorn cars.
TomB is offline   Reply With Quote
Old 02-22-2012, 02:11 AM   #1787
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Can someone post a photo of the MTX5 with normal size steering and throttle servos please?
Michael_T is offline   Reply With Quote
Old 02-22-2012, 02:32 AM   #1788
Default servos
i hope you have plenty of patience if you are putting them together bailey tried for a long time and when they went together he did not know what he did i changed oil front diff i can't say it was much easier than 4r but that was me //plastic gears still good in front so i put it back together
greg
greg.dawn is offline   Reply With Quote
Old 02-22-2012, 04:18 AM   #1789
Mike two full size servos fit. You may find you need to space the throttle servo out by 2mm to get some space for the cables to run between the tank and the bottom of the throttle servo which rests almost against the tank.
i had to modify the servo tray to fit my low profile ko servo as the wire exited the servo against a plastic part. If you have patience and you are ok with dremeling go ahead and get the low profile servos. The car was designed with full size servos in mind so it's sort of a waste of time to use two low profile servos, unless you use a light weight battery on the other side to balance the loss of weight from one side with the other...i'm not gonna race in sanctioned events soon...so you know.. a few less grams for a club day *cough*
Old 02-22-2012, 04:54 AM   #1790
Bishop's Avatar
I had an easier time fitting two low profile Savox, than I did with two full sized servos, and had to mod nothing to fit the Savox LP's...
http://www.bishopsraceblog.com/?page_id=221
Actually, I did mod something, the Savox have a bulky wire grommet, I pulled away the outside section of the grommet so the wires could then fold flat against the servo cases, shimming of the servos also goes without saying, you shim to suit the servo and horn your using, and I needed to borrow some from an older kit as the 'five' kit did not come with enough.
I'm all for the modern myself, LP servos are great, and would never go back to a NiMh battery either, LiFe packs are great, downside is I'm going to fail any weight check right now, so busy still sorting the car I honestly can't be bothered working out where to put weight till it's necessary, or when YBSlow churn out the brass engine mounts...
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 02-22-2012, 04:10 PM   #1791
Jeff Hamon's Avatar
My solution to the weight..... Brass weight for centre slider 43g by Podified Engineering. Engine Mounts coming soon.....
Mugen Seiki
PROTOform
HotRace Tyres
www.direct-hobbies.com
Jspec Stickers
Jeff Hamon is offline   Reply With Quote
Old 02-22-2012, 05:38 PM   #1792
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Podified Engineering/Engines FTWMF!!!!!!!
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 02-22-2012, 06:24 PM   #1793
kickass's Avatar
Jeff you are up for a new chassy mate that car looks like its up for a 100k service.LOL
I put the first scratch on my chassy this week- the car feels really cice
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 02-22-2012, 09:37 PM   #1794
Jeff Hamon's Avatar
lol Alex, good to hear that the car was good, keep it up and make sure you let me know if there is anything you need.
Mugen Seiki
PROTOform
HotRace Tyres
Jspec Stickers
Old 02-23-2012, 01:17 AM   #1795
looks good Jeff. Can you post a link so we can purchase?
It would be great to have a choice of centre weights to play around with distribution and to have the option of making the car very light and placing the required weight in the centre.
I'm dying to race my 5...no tracks within a cooee from where i'm ATM
Old 02-23-2012, 11:38 AM   #1796
Default optional
http://www.race4fun.it/dettagli.asp?...457&categoria=
I bought this for 96g fantastic
biagio23 is offline   Reply With Quote
Old 02-24-2012, 12:06 AM   #1797
Originally Posted by biagio23 View Post
is the wieght stuck on to the chassis with tape??
Old 02-24-2012, 02:05 AM   #1798
Bishop's Avatar
The Podified slide weight looks good, next on my shopping list...
But I'm feeling a bit RC broke right about now.
QRCCRA
www.qrccra.org.au
Old 02-24-2012, 10:02 AM   #1799
is no stop to the frame as the original weight
Old 02-25-2012, 11:26 AM   #1800
Bishop's Avatar
I missed these being added to the Mugen site...
http://www.mugenseiki.com/t2131_t2132e.htm
Revised inserts for the front links, supposed to improve steering response, an issue some have had but other not, possibly a track/setup thing, but I'm keen to try a set...
QRCCRA
www.qrccra.org.au
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
