MTX 5
Old 09-30-2011 | 08:58 PM
  #1036
Bishop's Avatar
Originally Posted by 30Tooth
Thats good to know Bishop,I just dont understand what you did by pushing in the top shock mounts,you meant shock position or really pushing the top mount into the shock body?For the record I haven't received my car yet.
Sorry, yes moved in the top shock mounts one hole, but I think just the drilled holes created what I wanted, so I could move them back out one hole again.
For a bumpy low/medium traction track, the stock 1.1mm 1 hole pistons with 600 oil just did not work for me, so 2 hole pistons for me, though someone else at the track said they would try the Mugen 1.3mm 1 hole pistons.
Bishop is offline
Old 10-01-2011 | 09:46 AM
  #1037
Originally Posted by afm
Que pasa pepe, hay que asentar los frenos pues...estan nuevos
Slds
Papo
Je, je si Papo, ya me di cuenta.... es que con los sistemas anteriores, sólo gatillando el freno, se bloqueaban las ruedas... Claro, se bloqueban cuando eran nuevos, pero en la pista, ni bien se calentaban un poco, los frenos se hacían humo.... je,je
yshmana is offline
Old 10-01-2011 | 01:49 PM
  #1038
danjoy25's Avatar
Lost rear diff action and the pic shows the culprit. Might try alloy gears
danjoy25 is offline
Old 10-01-2011 | 02:24 PM
  #1039
Danjoy25,
I recommend you use the rear diffs of the nt1, they go perfect... for the front, use originals of carbon.. I lost a run using rear capricorn diffs in my nt1. Now, in my mtx5, I use rear diffs xray nt1.
Use rear carbon diffs for semis and finals.....
Regards..
yshmana is offline
Old 10-01-2011 | 02:29 PM
  #1040
Slds
Papo
Papo, tengan mucho cuidado con el desgaste de los diferenciales de carbono traseros.... ya vieron lo que me sucedió en la final en machala...
Los diferenciales metálicos de xray nt1 van perfecto.
Saludos.
yshmana is offline
Old 10-01-2011 | 03:18 PM
  #1041
Default DIFFS XRAY NT1
this is the car part: 335030 diff bevel & satelite gears (2+4)
yshmana is offline
Old 10-01-2011 | 07:01 PM
  #1042
Saludos.
que lastima que ya ay problemas con los diferenciales.. ya me lo veo venir se me asen mierda el engranaje en un momento importante del dia
TomB is offline
Old 10-01-2011 | 07:02 PM
  #1043
1.3 isn't enough bro. plus 2 hole pistons feel smoother and work better than 1 hole pistons. the oil moves through the shocks better.
TomB is offline
Old 10-01-2011 | 07:16 PM
  #1044
Así es TomB... se sacrifica peso por duración....
yshmana is offline
Old 10-01-2011 | 07:24 PM
  #1045
JRGTR's Avatar
se siente raro leer en español en este foro!!! que bueno ver muchos colegas de habla hispana corriendo Mugen!!! mugen power y latino power!!!
JRGTR is offline
Old 10-01-2011 | 07:26 PM
  #1046
JRGTR's Avatar
TomB en que posicion tienes los amortiguadores delanteros en el medio , arriba o abajo? y de que medida es la barrena para perforar el piston del amortiguador?
gracias!!!
JRGTR is offline
Old 10-02-2011 | 04:32 AM
  #1047
Roelof's Avatar
Would you mind to write English?
Roelof is online now
Old 10-02-2011 | 10:01 AM
  #1048
Thumbs up
Maybe they should start writing in chinese , or russian , this way they can feel smart, or is it that they can't speak English , refuse to conform to the thread agreements or any sensible form of common communication !!! They will probably start writing in English in all the Spanish forums, just to let people know they can say a few English words ! That should tell the Moderators how "smart" a few can be, and that they should enforce a common language, just so it doesn't become a culture clash here !!! It is also profoundly disrespectful to continue writing in another language in the obviously English forums, and I think it is their intent to create controversy in an otherwise peaceful community !!!! Moderators should put a stop to this before it worsens !!! Stop forcing the Spanish Language down our throats, and go back home !!!
bertrandsv87 is offline
Old 10-02-2011 | 10:04 AM
  #1049
Bishop's Avatar
Just based off how well my electric gets round the track lately, I'm going to emulate it's setup, so yeah soft all round for me, 2 hole pistons, purples, 450cst, and I'll see how all that goes, and stiffen up where needed.
Though I'm not about to say it would work for everyone, just that I like a fairly soft setup.
Bishop is offline
Old 10-02-2011 | 10:20 AM
  #1050
VexVegaz's Avatar
Bert I hear what your saying and you present valid points, but was this really necessary? WOW
VexVegaz is offline
