Speed Passion Thread
#453
You can if you want. I run a fan on both my wheeler and SC truck with a overtray cuz theres no airflow. 2wd I don't.
#454
Just wanted to add I recently got a GT 2.0 LPF and put it in my FT T4.1 and I love it. I waited to put my fan on the thing but it got a little warm and it has run perfectly in two days of racing/practice. Changes are easy to make and instructions are informative. And big thanks to Albert for all of his help! Without having to go over thirty pages of info has anyone used their Ultra Sportsman V2.0 motors? I am thinking about getting a 7.5 or 8.5 to run in my truck instead of the 10.5 I have.
#455
Sorry if this has been asked before, but what are the main differences between the SP GT 2.0 pro and the non pro, I'm looking to get the esc for my FT B4 but just wanted to make sure if there is a reason to spend 40 bucks more on the pro version....... Thanks
#456
For your B4 the LPF would be fine.
#457
On another note, has anyone run the SP speedos with non sensor motors? Is there a setting change to make with the LCD? Or just disconnect the sensor cable? I know if I was on the track, and there was a cable failure, I would see a output difference. I dont know for sure what to do.
#458
The nice thing about the LPF is the way it fits under the body. Not sure how tall the 2.1 Pro is, but I know my 2.0 Pro with fan won't go under a B4 body. Been running the LPF for about 3 months now. Track temps above 120 last weekend and after 6 minutes motor temp was under 130, speedo was about 120, after 12 minutes both were a little over 140. That was with a 17.5 with boost abd turbo maxed to 64 deg, but it's been similar with an 8.5, no boost or turbo. Love the 2.0 Pro in 4wd.
#459
Anyone have any direct contact for Speed Passion.
I have been trying for over a month to get an RMA number on the web site and constantly get a Internal 500 error every time I hit submit. I have tried on 2 machines at 2 different locations with 3 different browsers and same thing. So started sending emails the last couple weeks asking for an RMA number and explaining what is going on, and no response. Then this last week I start to call because my warranty is up soon, They answer take my name and number and say they will call back and never do.
Seriously this is ridiculous. Any Ideas on how to get them actually do something and fix my stuff.
Rob
Rob
#460
Rob
Rob
http://www.rctech.net/forum/members/solara.html
#461
Go with the 2.1 Pro Stock, for the b4.1. It runs anything you want. I run 7.5 with no fans no problem in my 2wd Cougar SV.
#463
#465
But still, check ESC TEMP and add fan if you think it is needed.
4Likes
