Speed Passion Thread
#301
Glad to know that...and thanks for supporting us. Let us know how much of a different....
Remember....BOOST 323stock is no longer only used for stock motor now, our driver has tested the software in and out and has been using it with 6.5 7.5 on 2WD 4WD and SCT and has great result....
All setup sheet are listed here...
http://www.speedpassion.net/us/escsetup.asp
As flat, smooth, and linear as possible is the way to go!
#302
You are correct...alot of our driver PREFER not to boost....straight 205 and 6.5 motor is PLENTY fast for them. Our setup show most of the setup are straight 205, no boost/SC.
#304
#308
Im running my first Speed Passion set up. Silver Arrow 2.0 & Cirtix or what ever its called 2200kv in my 1/8 truggy on 4s and seems to be decent. Motos not that great, but the ESC is solid. I know its a Hobbywing Xerun, but thats OK! Hobbiewings great!
#309
#310
Do I need to order the fan for the esc? one is prostock with a 17.5 in 2wd buggy and the other is the ex that will run a 6.5 in 4x4 buggy.. the website says the fans are for the 2.0? just curious and thanks in advance..
jason
jason
#311
I'm considering buying this combo, but I want to be able to compete - are you saying that you can't do that with a Cirtex motor?
#312
They both come with fans. You won't need the fan for the 2wd, but using it in the 4wd would be a good idea.
#313
Its not that great for heavy 1/8s. Its only 36mm in diameter and seems to run pretty warm. I have it geared very conservatively to keep it at 160 in my 1/8 truggy.
#315
The EX version is not a good choice for the 6.5 4x4. The EX is mostly intended for 1 cell. Suggest either a 2.0 PRO or 2.1. Or if you already have them, maybe switch the 2 around, the EX can handle 2S with milder motors as I understand it.
4Likes
