Team Associated RC8Be Thread >
Old 08-08-2011 | 11:34 AM
  #6811
anyone have try those a integy heavy duty center bulkhead ? any good ?
taztal3 is offline
Old 08-08-2011 | 01:03 PM
  #6812
Default tires
what tire r u guys run and what type of track r u on?
special_k is offline
Old 08-09-2011 | 04:09 AM
  #6813
Default LRP gearing
Hi everyone, i've built my RC8Be with an LRP SPX8 combo, Vector 8 2800kv motor, and in 10 min the esc died, lot of smoke, and the motor was hot and burn too! I was using a 17T pinion with a 4s Lipo, is this the problem?
i'll appresiate any help!!!
manuelargentina is offline
Old 08-09-2011 | 05:10 AM
  #6814
Haha. A 2800kv motor for starters .
I'm running a 1900kv with a 19T pinion on it and temps remain at optimal level.
17T on 2800kv -- Your ESC did exactly as it should. Burn out
To fix this buy a motor 2200kv or lower. I wouldn't run more than a 15 or 16T pinion with the 2200kv.
Sarinexia is offline
Old 08-09-2011 | 06:16 AM
  #6815
snapplane's Avatar
It just sounds like the motor was over geared. A 17T pinion on a 2800 sounds really high. I know a buddy of mine that is running a 2650 and he has gone through 3 different escs. I am running a 2200 and have had no problems. Even on hot days in the 90s my motor only will get up to about 140 while my esc only gets up to about 120 after a 10 min main.
snapplane is offline
Old 08-09-2011 | 07:24 AM
  #6816
DoogieLee's Avatar
Originally Posted by SEF
Use a 19 to 21 tooth depending on track size.
What pistons are you running? 10x1.1 use anywhere from 25-30 wt oil. 8x1.3 use 30 to 35 wt oil. I never really had my car feeling dialed with stock pistons, so I'm not sure what works best if you run stock pistons.
I have bought both sets of pistons for my shocks, but I still run the stockers for now, what applications do you use for the specific pistons?
Right now I have the JR Mitch setup in my car, minus the option pistons as I didnt have them at the time, and for me its pretty good, some minor push in the front end on tight turns, but nothing I cant live with.
DoogieLee is offline
Old 08-09-2011 | 08:51 AM
  #6817
hey
so is there any news of new electric buggy coming coming out for associated ?
bardynt is offline
Old 08-09-2011 | 03:07 PM
  #6818
Lynxette's Avatar
Originally Posted by bardynt
hey
convert it. doesn't come with motor anyway
Lynxette is offline
Old 08-09-2011 | 04:40 PM
  #6819
DJLeonardo's Avatar
That also depends on the quality and type of the motor. I ran my SC converted RC8e (= heavier) on a Neu 1512 (2650 Kv) on a 19t-44T and it became 62 Celcius without fan (that's 143F for you guys) The MMM was cooler then that.
Also I run the 1515H 1Y (2200Kv) on a 23t-44T now and it runs way cooler because of the build-in fan. This is all offroad bashing on and off the track
DJLeonardo is offline
Old 08-09-2011 | 06:28 PM
  #6820
the only AE set up sheet for the rc8be has the same set up with the 2800 motor using a 14-46 gearing and coming off at 180 deg.
hammer down is offline
Old 08-09-2011 | 07:45 PM
  #6821
Default First run with the worlds kit.
Today was my first run with the worlds upgrades installed.
Chassis, towers, b plate, and modified arms.
The shocks had 30w oil, 8 hole pistons. One other change i made from my previous set up was I am now running 18 deg caster rather then 14.
Now I am by no ways a good driver. Just average. But the car now runs smoother through the bumps, corners better, handled the whoops much better. Visusaly you can see the car is much smoother in the bumps.
I can also power through the corners better. Maybe this is the caster change but.. I can tell you that I lowered the inner camber link on the rear and the rear end became much more planted. Then I moved the mount for the swaybar in 5mm and it got better.
The 30w oil is to light now where befor it was good. The buggy was to bouncy down the straight and it bottom hard, even with the heavest springs.
I'll go to 32.5w and see. But that just till my 2 stage pistons come in then back the drawing board.
Overall I feel there has been a significant improvement. Now to further fine tune
Old 08-09-2011 | 08:07 PM
  #6822
yer but i dont have the associated buggy yet
prob wait till sept and oct there is meant to be a few different buggies out then
bardynt is offline
Old 08-11-2011 | 05:15 PM
  #6823
jwmustang's Avatar
Im gonna try grease in my center diff. It runs hot, I want to see if this stops that. I had 10k oil in it. The Superlube grease has a lot less ressistance. feels like 5k oil. Update, on grease on the outdrive cups. I ran 30 to 40 batts with green grease on the cup shaft and they are still perfect. So that is an improvement over FT black grease. If weather permits I will race this weekend & update you.
jwmustang is offline
Old 08-11-2011 | 08:00 PM
  #6824
Arigato's Avatar
After running mine for a year I was considering a new kit. Instead I got the worlds kit arm, towers, b plate, 10 hole tapered pistons and light blue kyosho springs and BCE chassis. All I can say is WOW, what a difference! The car just works better; a lot better.
Arigato is offline
Old 08-12-2011 | 08:00 PM
  #6825
derekbsmith's Avatar
Default mud guards
Do these fit the RC8Be and are they worth it?
http://www.amainhobbies.com/product_...SC8-Mud-Guards
thx!
derekbsmith is offline
