Team Associated RC8Be Thread >
Old 05-18-2011 | 01:59 PM
  #6061
schnellschnell's Avatar
Originally Posted by kaiser
lol @ the triangle thingy's. i "lol'd wut?" when i saw them.
that motor mount looks good, but it also looks like it raises the c.o.g. quite a bit.
From the pic it is hard to tell, but I suspect that they left the center diff riser in place. Most find enough clearance without the riser, thereby lowering the CoG by lowering the diff and motor / mount all together.
j
schnellschnell is offline
Old 05-18-2011 | 02:44 PM
  #6062
DoogieLee's Avatar
When going to the Grid mount, whats the difference/benefits of either the one with the inner pinion support and the outer?
Thanks,
DoogieLee is offline
Old 05-18-2011 | 02:49 PM
  #6063
JWSCTE's Avatar
atm i'm running a 15t with a 2250kv on 4s. it seems perfect.
i may go up a tooth or 2 just to see, but i'm happy with it right now.
Is anyone runinng a 2000kv truggy motor in there RC8Be ? seems like it would have more torque than the 1900kv motor?
JWSCTE is offline
Old 05-18-2011 | 06:16 PM
  #6064
Thanks,
You have more selection of larger pinions with the inner support. The outer one restricts the maximum pinion. Most get the inner one for the RC8be.
edit: Outer support pinion sizes 13-17, inner pinion can choose from 13-22. Most use the 19 and up.
There is the option to get both as they can be purchased separately.
j
Old 05-18-2011 | 06:29 PM
  #6065
Suspended
j
Yeah, I didn't use the diff riser with my mount. There was no need for it. I found the pinion was to high up against the spur anyway.
Sarinexia is offline
Old 05-18-2011 | 06:33 PM
  #6066
gotta say this buggy has made my awful driving ability seem decent lol love how well this thing hooks up
youbleed is offline
Old 05-18-2011 | 06:41 PM
  #6067
rednck21's Avatar
anything i can do to get more steering out of mine...on and off power? just doesnt seem like it wants to turn like it should my setup...
5/5/2
medium springs all around
32.5 f, 30 r
ft beveled pistons or whatever they are
medium sway bar front, light bar rear
16-18 deg of caster??
ive tried 4/4/2, and i think im going to try 7/5/2 this weekend. tried different sway bars and no luck. any ideas?
rednck21 is offline
Old 05-18-2011 | 11:25 PM
  #6068
DoogieLee's Avatar
j
Thanks, that clears it up
Old 05-18-2011 | 11:49 PM
  #6069
DavidR's Avatar
R/C Tech Elite Member
5/5/2
32.5 f, 30 r
Here's how I tune my sway bars... Sway bars have the biggest effect on the opposite end of the car.
Putting a light bar on the rear and a stiffer one on the front is hurting your turning ability.
I myself run the gold bar (thickest) in the rear and no sway bar on the front on tight indoor tracks.
Raise the roll center in the rear (drop the inner camber link) and that should help the car rotate a bit better also.
Try 5/5/3 or 5/7/3 on your diffs (you could keep the 2 in the rear also if you wanted).. Running heavy fluids in the front will not help the car rotate.
-David
DavidR is offline
Old 05-19-2011 | 04:07 AM
  #6070
oldandnew's Avatar
j
What is the center diff riser? Is this something that comes with the Grid Mount? And if you order the inner mount does it come as shown in the pic. last page? i.e. with the Grid top plate? Thanks
oldandnew is offline
Old 05-19-2011 | 05:20 AM
  #6071
It comes with your car, not the grid mount. It sits directly under your diff. Its just a machined piece of metal that increases the height of the center diff
GaRsNoW is offline
Old 05-19-2011 | 05:22 AM
  #6072
5/5/2
32.5 f, 30 r
Thickening up your front diff fluid will only hurt your turning ability. I run 5/7/3 and I find this the best setup for my tight indoor track.
Also try moving your front wheels a few degrees toe'd out. This will help gain a few more degrees of turning
GaRsNoW is offline
Old 05-19-2011 | 06:21 AM
  #6073
mrgunz's Avatar
I'm sure its been well documented, but the stock motor mount is garbage IMO! I know this is a longshot, but anyone have an elite mount they want to sell???
mrgunz is offline
Old 05-19-2011 | 06:31 AM
  #6074
symmetricon's Avatar
5/5/2
32.5 f, 30 r
How are you shocks mounted? If you need more steering, try laying down the shocks more. Bring the shock mount on the shock tower closer to the center of the chassi.
symmetricon is offline
Old 05-19-2011 | 07:01 AM
  #6075
pbomstad's Avatar
Good luck I have been trying for months to get one. It would appear that elite only makes one of those per month. I have been watching their site for about 6 months and have never seen the rc8 mount in stock.That sux too because it looks like a excellent Upgrade.
pbomstad is offline
