Like Tree1Likes
Go Engine USA 2011 Thread
Old 07-14-2011 | 06:20 PM
  #1816
Jeauxkor's Avatar
Jeauxkor is offline
Old 07-14-2011 | 06:23 PM
  #1817
all ready for the big race weekend!!! made a few changes from last race so we will see if i can do better than 3rd
inferno13 is offline
Old 07-14-2011 | 06:57 PM
  #1818
crappy phone pics^^^
Old 07-14-2011 | 07:20 PM
  #1819
grizz1's Avatar
Originally Posted by Jeauxkor
What size front bearing for the GX-II? Is the stock bearing as good as the many after market brands?
Front is 7 x 19 x 6. Main is 14 x 25.4 x 6
The stock front bearings are SKF, so no need to upgrade.
Like Matt suggests, run seals on both sides if you can. They come from the factory only sealed on one side these days, but it's easy to slip a spare seal in before you install.
Looking GOOD !!!
That's a nice stable of race cars you have there inferno
grizz1 is offline
Old 07-14-2011 | 07:32 PM
  #1820
Looking GOOD !!!
thanks grizz! starting to get into the electric 1/8 sc class, not sure im like'in the radio shack stuff! might just to get another GXII to throw in it...
Old 07-17-2011 | 06:09 AM
  #1821
hey guys, I have a quick question for you. Can you tell me what the stock sleeve timing and crank induction timing are on the GX-II motors? Very interested in these.
RodneyPierce is offline
Old 07-17-2011 | 06:14 PM
  #1822
curacing2's Avatar
Thats a very technical question Rodney that few or any of us would have the answer to, what ever it is Go Engines got it right.
curacing2 is offline
Old 07-17-2011 | 06:55 PM
  #1823
Curacing, it is a technical question. But there are people out there modding these, so I hope to god they know what the numbers are before they start cutting.
Old 07-17-2011 | 07:04 PM
  #1824
houston's Avatar
Tech Prophet
ask rex welch
houston is offline
Old 07-18-2011 | 12:07 AM
  #1825
jnc011994's Avatar
Originally Posted by houston
ask rex welch
hi monty, whose rex welch? anyway, question on GXII. Practice run and engine runs good. Idles great. I wanted to put some more low end grunt. Using Losi 2 alum/green 2 comp./gold. So i adjust 1 hour on low speed needle, blip blip blip blip / WOT and engine dies... returning back to its setting 1 hour back, engine runs good. Why is that so?
Thanks,
jnc011994 is offline
Old 07-18-2011 | 04:24 AM
  #1826
grizz1's Avatar
Thanks,
Rex is 22Racer on here. He mods and repairs engines for a living.
I suspect the way you have your engine tuned, you are going too far in on the bottom end. Do you lean or richen the bottom end when it dies ?
The GXII (like the GX and it's predecessors) has a long tapered low speed needle. This tapered needle sits well inside the receiver jet. If you set it too far in, you can actually completely block off the receiver jet with the taper.
Craig (curacing2) our GO team driver here posted some info on this a few pages back somewhere too.
Race tune generally on the GXII will see the bottom needle screw flush or maybe 1/2 a turn in from flush with the cap. High speed needle the same.
I suggest you go back to flush on both needles, set the idle gap to .7 mm max, and tune from there.
The GXII has mega bottom end, so you shouldn't have a problem getting the performance you want.
grizz1 is offline
  #1827
rider313's Avatar
Rex Welch is the owner of RW Mods. His screen name is 22racer on here.
rider313 is offline
Old 07-18-2011 | 06:58 PM
  #1828
jnc011994's Avatar
thanks shane, rider.. yeah i've seen 22racer here. Yes shane i have leaned the bottom, engine dies; richen up and it engine ok. From what you've describe. Will restore back to flush settings and start from there, and also the .7mm idle gap.
many thanks....
Old 07-18-2011 | 08:23 PM
  #1829
grizz1's Avatar
many thanks....
I think that might be the problem. To give it more bottom you would normally richen the bottom a little.
Check out our tuning guide and other info here -
http://go-racing.vpweb.co.nz/Tech-Tips.html
grizz1 is offline
Old 07-21-2011 | 04:33 PM
  #1830
sriley's Avatar
Will a GX-5R venturi work correctly in a MG-66?
sriley is offline
