Team Associated RC8Be Thread >
Old 07-03-2011 | 09:22 PM
  #6541
rustler001's Avatar
quick question guys
for the front shocks
the top nut that screws in from the front of the car
when screwed in all the way(nut inside the shock cap), is that a lot of play in the shocks? i can move mine a good 3-4mm back and forth =/
rustler001 is offline
Old 07-03-2011 | 09:37 PM
  #6542
Originally Posted by rustler001
quick question guys
Your bushings are worn they should spin not move forward or back
http://cgi.ebay.com/NEW-TEAM-ASSOCIA...item3cb970099b
Radarmy088 is offline
Old 07-03-2011 | 09:44 PM
  #6543
rustler001's Avatar
the bushings arnt moving?
the bushings are staying put, the cap itself along with the shock move
Old 07-03-2011 | 10:00 PM
  #6544
But those bushings keep the shocks from shifting forward and back but allow them to turn as the suspension compress'
Old 07-03-2011 | 10:02 PM
  #6545
rustler001's Avatar
does the front bushing have to be flange? cause the one on there right now isnt a flange bushing like the rears.
  #6546
arvint's Avatar
I have that same problem..and I have brand new bushing/shocks/etc.. :/
arvint is offline
Old 07-03-2011 | 10:23 PM
  #6547
Same link they also include the Shock standoff's which are what the bushings go over and there is a lip to keep the bushings in place. Maybe the shock cap bushings hole is reamed out to where it's going over the bushings and the lip of the shock standoff.
Here are the standoff's
http://cgi.ebay.com/Associated-Shock...#ht_2207wt_891
Old 07-03-2011 | 10:25 PM
  #6548
rustler001's Avatar
mine stops at that lip =/ seems like this problem would be harder to figure out than i thought it would
oh btw, arvint, hi, its mycro from urc lol
Old 07-04-2011 | 12:04 AM
  #6549
yes it does need to be flanged .they do wear out and its the flange that wears,so they get sloppy.i also use a nylon washer before i put the nut on,seems to keep them tight longer.dont forget theres a front and back to the shock caps.they only fit really good one way.
BC slasher is offline
Old 07-04-2011 | 01:20 AM
  #6550
Diggity's Avatar
Default Rear Chassis Brace Stiffiner Insert
Team Associated RC8B/RC8BE and RC8T/RC8TE - New 2.5mm rear chassis brace stiffiner inserts. Similar to the ones used by Maifield and Cavaleiri.
Checkout the website for more info.
Diggity is offline
Old 07-04-2011 | 05:03 AM
  #6551
for those with leaking diff problems. I have used a gasket maker. Right now I am using some yamabond from the motocross days. A thin film on the gaskets and no more leaks. Dont use to much so it dont squish into the diff.
neither the slash or rc8b leak now
hammer down is offline
Old 07-04-2011 | 05:51 AM
  #6552
JEFFs SC10's Avatar
I can testify that Yamabond works. We used it on high boost applications in lsx cars with success to seal headgaskets. (on real cars LOL)
JEFFs SC10 is offline
Old 07-04-2011 | 06:32 AM
  #6553
jwmustang's Avatar
Originally Posted by Deaner
So I finished putting my kit together today, wired up the speedo and the motor... noticed the center diff was leaking. So when you guys sand the diff sealing surface do you just sand on say, emery cloth on a flat surface? Or a bigger piece of fine sandpaper?
Is there really any type of torque spec for the diff itself?
do you just sand on say, emery cloth on a flat surface? Yes.
jwmustang is offline
Old 07-04-2011 | 08:43 AM
  #6554
jessbens's Avatar
whats the web site for them chassis brace stiffiner inserts.
jessbens is offline
Old 07-04-2011 | 09:16 AM
  #6555
http://www.diggitydesigns.com/D3_Off...ated_RC8B.html
jhhack is offline
