Team Associated RC8Be Thread >
Old 07-04-2011, 10:56 AM
  #6556
Manshoon's Avatar
Originally Posted by Diggity
Team Associated RC8B/RC8BE and RC8T/RC8TE - New 2.5mm rear chassis brace stiffiner inserts. Similar to the ones used by Maifield and Cavaleiri.
Checkout the website for more info.
Drilling holes into a plastic brace ?
Manshoon is offline
Old 07-04-2011, 02:58 PM
  #6557
rustler001's Avatar
Originally Posted by BC slasher
yes it does need to be flanged .they do wear out and its the flange that wears,so they get sloppy.i also use a nylon washer before i put the nut on,seems to keep them tight longer.dont forget theres a front and back to the shock caps.they only fit really good one way.
replaced it with a flanged one, it still plays =/ not as much, but its enough to make me nervous
the nut ends up going inside the shock cap, right? cause one way, the nut sits on the outside, the other way, its inside
rustler001 is offline
Old 07-04-2011, 06:16 PM
  #6558
rc person 577's Avatar
Yes, inside the shock cap. My caps have a bit of play in them. I had the grind off the outside of my wrench to fit it inside the cap. They have 2-3mm of play, and I didn't have any problems at the track. The hole should be bigger in the cap IMO...
rc person 577 is offline
Old 07-04-2011, 06:26 PM
  #6559
rustler001's Avatar
Originally Posted by rc person 577
Yes, inside the shock cap. My caps have a bit of play in them. I had the grind off the outside of my wrench to fit it inside the cap. They have 2-3mm of play, and I didn't have any problems of the track. The hole should be bigger in the cap IMO...
yea, i got the AE 5.5mm nut driver which fits, so im all good lol
seems like im all good for now
Old 07-04-2011, 09:50 PM
  #6560
DRUNKENMASTER's Avatar
Default Suspension upgrade installed. Pics.
You have to modify the caster blocks... easy to do with Dremel.
upgrade adds more droop..
3mm chassis and B-plate up next to come!
DRUNKENMASTER is offline
Old 07-04-2011, 10:04 PM
  #6561
Deaner's Avatar
Originally Posted by hammer down
for those with leaking diff problems. I have used a gasket maker. Right now I am using some yamabond from the motocross days. A thin film on the gaskets and no more leaks. Dont use to much so it dont squish into the diff.
neither the slash or rc8b leak now
Thanks, that's a great idea!
Deaner is offline
Old 07-05-2011, 12:45 AM
  #6562
BLbound's Avatar
Trader Rating: 27 (100%+)
Thanks for the pics! All I have left is the front end to do
BLbound is offline
Old 07-05-2011, 07:05 PM
  #6563
Just painted my new body almost ready for the track.
Radarmy088 is offline
Old 07-05-2011, 08:21 PM
  #6564
rustler001's Avatar
crappy video of my first ever run for you guys lol
ignore my crappy quality video and crappy driving lol, driving with 1 hand is hard, and trying to make a dog STFU is harder
oh boy this thing is awesome, it turns on a dime O.o
+ YouTube Video
Old 07-05-2011, 08:46 PM
  #6565
Default worlds B plate
I know the advantages of the+3mm and the new arms and towers.
Whats the advantage of the new B plate
hammer down is offline
Old 07-05-2011, 09:52 PM
  #6566
BLbound's Avatar
I hope the raiders make me proud this year...mostly I hope there's a football season!
BLbound is offline
Old 07-05-2011, 10:00 PM
  #6567
Stealthpilot's Avatar
Which length Kyosho light blue springs do you use front and rear? Thanks.
Stealthpilot is offline
Old 07-05-2011, 10:09 PM
  #6568
BLbound's Avatar
I'm 99% sure what's needed is the 70mm front & 84mm rear light blue.
BLbound is offline
Old 07-06-2011, 11:31 AM
  #6569
ffiB's Avatar
Looks like Ill be joining yall soon.
Team Associated RC8Be Factory Team 4WD 1/8 Buggy Kit
Tekin RX8/Redline T8 1/8th Scale Buggy Brushless ESC/Motor Combo (1900kV)
http://www.hobbyking.com/hobbyking/s...dProduct=14983
http://www.amainhobbies.com/product_...ium-Gear-Servo
http://www.amainhobbies.com/product_...Setting-Module
Got a few other odds and ends to get yet.
ffiB is offline
Old 07-06-2011, 12:29 PM
  #6570
rednck21's Avatar
Trader Rating: 106 (100%+)
part numbers?? whats the advantage to running these springs?
rednck21 is offline
