Like Tree2Likes
Xray T3 2011
Old 06-10-2011, 02:02 PM
  #2371
Trader Rating: 17 (100%+)
i just picked up one of these cars,, what motor is everyone using
i have a tekin rs pro and 7.5 motor will that work
bkuff-losi is offline
Old 06-10-2011, 03:59 PM
  #2372
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by S.A.W
What wt oil would you normally use for asphalt and carpet ? and how do you know when to go thinner or thicker ?
Do you also change depending on track/air temperature etc ?
Thanks.
450 is a good starting point for asphalt
CraigM is offline
Old 06-10-2011, 08:35 PM
  #2373
Dane's Avatar
Trader Rating: 26 (100%+)
Thumbs up
It was mentioned a couple pages back but I have had huge success with the Hot Bodies TCX bladders. They need a filing around the edge but if you follow the xray guide for building T3'11 shocks, they come out perfect. Take it from me, I've been one of those "I don't like these shocks" guys. Now with these bladders, I'm a believer.
http://www.rcmart.com/catalog/rc-pro...3-p-16179.html
Dane is offline
Old 06-10-2011, 11:50 PM
  #2374
7.5 with the tekin is a good choise
Manson is offline
Old 06-11-2011, 01:30 AM
  #2375
That's what I'm cuurently usingg on asphalt, what about carpet ? 600-650 ?
S.A.W is offline
Old 06-11-2011, 02:33 AM
  #2376
blade072's Avatar
Trader Rating: 98 (100%+)
i am getting the t311 conversion kit soon for my t3......then i see that exotek have made a chassis for it now.....has anyone had a chance to try it yet??
also i noticed a couple of people in my club are getting the serpent so it will be interesting to see how they go against us!!!
blade072 is offline
Old 06-11-2011, 12:23 PM
  #2377
Heavier front oil usually works well on carpet, the rear shocks are usually about the same as asphalt.
Danny-b23 is offline
Old 06-11-2011, 11:55 PM
  #2378
Tron's Avatar
Why does xray use both 4.9mm and 5mm ballstuds and ballends? So annoying!
Is there any logic behind it?
Tron is offline
Old 06-12-2011, 04:16 AM
  #2379
I've found the schumacher mi4 bladders fit perfectly apart from not allowing the cap to screw down fully. But from an ease of build point of view they're much better than the xray pieces, rebound is much easier also.
Xray2011 is offline
Old 06-12-2011, 06:55 AM
  #2380
Fred Hubbard's Avatar
You're talking about the only (2) 5mm ball studs that attaches the drag link to the servo saver and steering plate correct? Not sure I understand what the issue is, they are easy to identify by how they are packed unlike how Tamiya packs their parts. With Tamiya you are better off opening EVERY bag and putting all the parts in a pile and starting your build unlike XRAY which is just the opposite
Fred Hubbard is offline
Old 06-12-2011, 03:28 PM
  #2381
Tron's Avatar
Hey Fred, what's up bud...It's not a problem really, just more spares to carry and the use is inconsistent...I don't understand why some 5mm bell ends are fitted to 4.9mm ballstuds, while the new upper clamps use 4.9mm ends with 4.9mm ballstuds, which is not done elsewhere.
I don't know the history of the previous xray cars so I'm not sure if the 4.9mm or 5.0mm is a carryover or a new item, so I wondered at the logic...in one aspect the 0.1mm difference may avoid binding, but from an engineering standpoint it is unrefined.
You know me, I'm pretty OCD about my stuff so was curious at the reasoning behind it.
Regardless, I'm out of the game for a bit, my Thunder Power rotor delaminated so I've got to send it in for a warranty check. As soon as I read you were with TP I discovered my rotor was whack, I hope it's not a coincidence
So you heading back to TQ to work on your game or staying at WC for a bit longer?
Tron is offline
Old 06-12-2011, 09:34 PM
  #2382
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I have a set of ECS 50mm and 52mm The question is. if I just switched the 52mm to 50mm ,what will I gain?
OVA is offline
Old 06-13-2011, 04:34 AM
  #2383
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Originally Posted by rcfiend
Does anyone know if parts from the Serpent S411 will fit the T3'11? It looks like a T3'11 knock off. I'm mainly interested in the shocks and the gear diff.
http://www.serpent.com/product/400005
Not sure how much research you've done. For the rear diff they are also using a 10x15 bearing and its a 38t setup as well. The way they designed it with only 1 set of bevel gears should keep it light weight.
nitrobeast is offline
Old 06-13-2011, 05:36 AM
  #2384
Hey Brett sorry to hear about the motor, hopefully everything gets worked out...sorry to jinx ya with my change We've got the asphalt nats coming up so I will be at WC until then and during the summer until about a month or so before the IIC then I'll be over at TQ. See ya when you come back
Old 06-13-2011, 08:08 AM
  #2385
RC MARKET's Avatar
Trader Rating: 12 (100%+)
XRAY testing his Gear Diff. ?
RC MARKET is offline
