Xray T3 2011
#2402
Does anyone know if parts from the Serpent S411 will fit the T3'11? It looks like a T3'11 knock off. I'm mainly interested in the shocks and the gear diff.
http://www.serpent.com/product/400005
#2403
I have been reading over some setup sheets and i see lots of drivers using shims to adjust ackerman. What i would like to know is what effect these shims have and which way to go to get a desired effect?
#2405
If you MUST have a ball diff, sand the rings with a very light sand paper (both sides) and build per the instruction but use Associated Black grease on the thrust bearing and Associated Stealth Lube on the balls. Keep it pretty loose (some slip) and work it with your hands. Then install it in the car, run a few laps, check it and tighten until it's smooth but without slip. Look at the video Jilles Groskamp did with RedRC. Excellent step-by-step.
#2406
I do prefer using the ball diff but the gear diff is sooo much easier.
My ball diff only last a few runs and they feel rough
must be the way I build/run it, I dunno.
#2409
EA
#2412
Say you have them on the "correct side" in and up then swap them from one side to the other but keep them in and out on the bridge.
Is it higher, lower, shorter or longer?
thanks
#2413
And less roll. Frees up the rear end significantly but still have good forward traction. I tested it on a tight med bite carpet track and it worked well. I flipped the fronts and it made it smoother but took away a good part of the corner speed. For now, regular L1/L2 in front and flipped L1/L2 in rear.
#2414
I'm pretty sure that swapping sides and using the same mounting orientation (in this case in and up) will raise the inner camber link mounting point, and shorten the link a small amount if the same camber settings are used in the rear. I've experimented with moving the blocks from side to side, but haven't found that "magic" setting quite yet...
#2415
If it raises the inner camber link i guess i can see it freeing up the rear.
What would be different then using the H1|H2 blocks? Just the shorter part?
