SC10 4x4 Thread
#2641
What kind of run times you guys getting with the 1410? I'm running it with a mamba monster and I'm only getting 14 min with a 40c 2s geared 13t 32p? My buddies running a a rs with the 550 4.5 and he gets close to double my run time, 25 min I'd say. Truck has no binding and motor is coming off at 155~
ThunderbirdJunkie's was all practice at the track going balls-out.
#2642
hi,
just would like 2 no if anybody can tell me where 2 get one of these trucks or a 2nd shipment date 2 stores, would like 2 compare against my losi and run the truck that works 4 me,im in the land downunder cant find one here,any help would be great.
thanks ,Scott
thanks ,Scott
#2645
First belt casualty...
Was replaced with a new belt and increased the tension and it happened again in the main. Both times I hit the brakes coming into a corner and the car locked up. Just taking off the front pulley cover provided the image above.
#2646
Check the back. Same thing happened to me and then culprit was thaT I didn't assemble the back tranny correctly. That's why I had to move the pinion all the way to the tip of the shaft. Once assembled correctly I had no more issues, and the pinion is now seated farther in the motor shaft
This problem didn't manifest itself immediately, but after 10-15 runs or so
#2647
#2648
#2649
My first time out with the truck without any practice I took the TQ and Win. I made some swaybars the night before the race an the truck felt awesome. This thing is going to be dangerous once I get some time on it. After the 8 minute A-Main I used 3000mah (Integy 5000mah 35c) (Tekin RX8 / Tekin 4.5 550)
#2650
So I'm running 5000wt diff oil in front and rear. I really like the way the truck drives. Problem is, this is my first experience with any kind of 4wd and have nothing to compare it to.
So my question is, does running 30000wt in front diff make that much of a difference in the way the truck performs? Is it worth the time it would take to change it?
#2651
Odin,
He is giving you an option of where to purchase the wheels at. He has also givin numerous setup and build advice on this thread. I don't think it's PATHETIC at all. The only thing that i see thats PATHETIC is that you took the time to actually post that PATHETIC post. Keep the thread on topic.
#2652
#2653
The guy's gone out of his way to help the owners through figuring out how to set up this truck, come up with solutions that AE has not provided us (IE shock o-rings and WHEELS)...yeah, real pathetic of him.
ThunderbirdJunkie has run DE wheels almost exclusively for the past 7 months, and that's not going to change, aside from the almost part
5Likes
at least at race speeds
(it works... it's just funny and fugly)
