SC10 4x4 Thread
#2251
This is my setup so far and I am very happy with the truck:
Front:
Stock Shock Spring
Stock Piston
Emulsion Style
35 Wt Oil
2mm front Bar
15K Diff Oil
Rear:
Stock Shock Spring
Stock Piston
Emulsion Style
30 Wt Oil
2mm Rear Bar
5K Diff Oil
Motor:
Team Epic 4.5 Turn 550 Motor
13T Pinion (32 Pitch)
The truck is amazing, it is very hooked up and turns in well. It actually drives much like a super hooked up 2WD truck. I am very happy with this setup as it jumps and lands very well.
Front:
Stock Shock Spring
Stock Piston
Emulsion Style
35 Wt Oil
2mm front Bar
15K Diff Oil
Rear:
Stock Shock Spring
Stock Piston
Emulsion Style
30 Wt Oil
2mm Rear Bar
5K Diff Oil
Motor:
#2252
I really don't understand why somebody would make a purpose-built off-road track with carpet and wooden jumps rather than dirt. At least I have something though, so I can't compplain too much.
Where I am there are two indoor carpet off road tracks within 5 minutes of each other.
Craig
#2253
The stock tires on my SC10 2wd worked great on carpet. Excellent foreward but and loose enough to slide nicely around the corners. I could probably use better tires on the front though as it pushed a lot under power.
#2254
I think this truck has every size from 6 to 18mm long on it.
#2255
I raced on carpet. I used some panther clay compound tires and ground them down to slicks. I had too much front bite so I super glued the outer 1/4 of the tire and was hooked up very good. I took 2nd over all with a field full of foam tire trucks.
#2256
#2257
#2259
I think the instruction manual has the belt tensioner settings reversed. Says to use the middle position for the back and 2nd to the most loose for the front. With that setup the belt was touching the upper belt cover in the front. I reversed them and moved the tensioner to the 2nd loose for the rear and middle for the front and getting no rubbing from the belt cover.
Also, someone did mention way way back that there is one 3/8 nut, I found this to be true as well.
#2260
Seems the slipper spring is almost completely compressed on mine for it not to slip much. I don't have the high torque pad yet though.
#2261
Yea i tightened it down all the way. it slips enough for me not to have any snap out of a corner something the center diff trucks seem to have alot of.
#2262
#2264
I used to crank bolt down 4mm now that its shimmed i can only crank it down 3.25 mm but its the same slipping. the shims just move everything
I really think its 550power > slipper pads
now i can finsih a race and place decent but i fight with it because it has no snap like the center diff trucks. and then when im done my slipper temps at 167
#2265
Mine will pull the front tires off the ground about 4 foot down the straight until the rear slipper pad glazes over. My thrust washer seems to be ok just does not seem right to need the slipper spring crushed.
5Likes
Its got to be a weak spring or something I'm going to pin it.
