Like Tree5Likes
SC10 4x4 Thread
Old 05-12-2011 | 05:24 AM
  #556
Just reading through this thread and looking at the vids posted, I'm stunned that AE didn't include sway bars with this thing. It looks like it should be standard, not an option.
Anyway, looking at the pic posted a few pages back, they don't look too different from the Losi sway bars. I bet you could make the Losi's work.
Just a suggestion. I'm sure this truck will be great but it looks like it is having some early teething problems just like I expected. All new vehicles do.
chiro972 is offline
Old 05-12-2011 | 05:33 AM
  #557
Ya, it seems to be going through some quality issues. That's what you get when you outsource to the lowest bidder.
Hopefully it will be worked out for the next batch. Maybe AE will start including the swaybars. I can't see them adding very much to the cost of producing the kit. Maybe a few cents per box?
CraigV is offline
  #558
Bburns's Avatar
well i finally can post some pics on here for you guys to see. im really happy with this truck.
Bburns is offline
Old 05-12-2011 | 05:58 AM
  #559
Jmuck69's Avatar
Originally Posted by offtraxx
finally got mine built. had enuf time to make a couple trips down my street. I din't want to abuse my good tires so the track will come today.
already tell the differance between the sc10 and the slash I ran last year. just the few turns I made in my yard was awesome for a 4x4. can't wait
anybody get any spare parts? I have both front and read pully''s and a few screws left over. I went thru the manuel again and know I din't miss any screws.
Be aware the "spare" pulleys are the 19t overdrive pulleys vs. the stock 20t.
Jmuck69 is offline
Old 05-12-2011 | 06:11 AM
  #560
JEFFs SC10's Avatar
What is the benefit advantage of 20 t vs 19t clicker?
I don't understand.
JEFFs SC10 is offline
Old 05-12-2011 | 06:15 AM
  #561
JEFFs SC10's Avatar
If you run the Savox servo with a MMP you need to run a capacitor right?
What are the specs of the Savox?
Old 05-12-2011 | 06:37 AM
  #562
mca.'s Avatar
Originally Posted by CentralCoaster
I forgot to check all the factory shock piston screws, and of course one came out and the shock came apart.
Also lost the screw in my servo horn. That is gonna take awhile to fix.
Does anyone have a vid on the fastest way to pull the servo?
I had to readjust my servo horn as it was not straight, was 20-30 mins work, basicly removed belt off just the front, unscrewed and removed the whole front half of the chassis, then went from there.
mca. is offline
Old 05-12-2011 | 06:38 AM
  #563
mca.'s Avatar
Originally Posted by socalrcer
Where are you measuring the ride height? I am measuring at the edges of the main chassis before it kicks up in the front and just behind the motor in the rear.
What ride height does everyone like?
I went with 27mm, measure as u said.
mca. is offline
Old 05-12-2011 | 06:42 AM
  #564
marksp's Avatar
Originally Posted by Keeferton
I got to race mine for the first time tonight. Overall I am very happy with this truck.
Track: High bite, blue groove, indoor track outbackraceway.com
Motor/esc: Castle 3800kv/MMP
Servo: XP ds1015
Tires: Green JC Subcultures
What pinion are you running? Any sensorless motor timing added? Thanks
marksp is offline
Old 05-12-2011 | 06:49 AM
  #565
murky123's Avatar
I got to race mine for the first time tonight. After an 8 min main the motor temped at 120 and esc at 130. I ran 7k oil in the front diff and 3k in the rear.
Servo: XP ds1015
I also wanna know what pinionu used and you MMP settings. and did you use the 32 pitch?
I have the exact same electronics.
Im thinking of a 32 pitch 13T pinion for a medium sized track
murky123 is offline
  #566
ffpm46's Avatar
Has anyone put the Losi SCTE sway bars on? Is there any mods necessary to make it work?
ffpm46 is offline
Old 05-12-2011 | 07:09 AM
  #567
Originally Posted by CraigV
What is the model of your Savox servo?
1258tg
mtnbiker67 is offline
Old 05-12-2011 | 07:18 AM
  #568
I don't understand.
If you run the 19t overdrive clicker it will make your front tires pull more then the rear allowing you more throttle out of the corner especially on loose tracks
Keep'N It Cool is offline
Old 05-12-2011 | 07:19 AM
  #569
Default Help needed
I just installed the belt (pg. 27) and went to check for free rotation. The belt when held and pulled towards the front clicker is just locked tight. If the belt is pulled towards the rear of the truck I get the clicker sound. I don't feel this is correct.
Could someone let me know if this is correct and if not, what I might have done incorrectly. I didn't over tighten the diff cases, made sure they weren't binding.
I went back over then manual and only thing that I can think of to cause this might be I installed the diffs with the screws facing inwards. I worked on this late into the morning when I wasn't the most awake and aware (not a good idea).
Thanks in advance.
isarctard is offline
Old 05-12-2011 | 07:21 AM
  #570
If anyone has a Blitz body, you can use it on your SC104x4, just have to turn the rear body mounts around so they are pointing towards the front of the truck, and you have to move the body mount holes in the front about 1 inch or so towards the back of the truck. The cut out for the rear bumper even fits the same. I did this with my son's old blitz body till I get mine painted.
