Like Tree5Likes
SC10 4x4 Thread
Old 05-09-2011 | 09:49 PM
  #151
Wild Cherry's Avatar
Tip :
If you need new rims the losi fit, but be aware the rim is a bit thicker and you may wish to use a brand new lock nut or lock-tite the wheel nut .
cause
a wheel may fall come off during your run if the lock nut is so , so ...
Wild Cherry is offline
Old 05-09-2011 | 09:50 PM
  #152
BlueGlowBoy's Avatar
Originally Posted by mca.
The SC10 4x4 has landed in Australia today! Thanks Tower & UPS!
Australia has the truck and Canadians are still waiting.... explain THAT one...
Does anyone have an actual length that the servo wire needs to be to get to the receiver box WITHOUT extensions? I have no issue running extensions if my Savox won't reach, but would like to know if I need to go get one now, before the truck arrives, rather than get the truck finished and have to wait for my LHS to open the next day so that I can get one...
BlueGlowBoy is offline
Old 05-09-2011 | 09:58 PM
  #153
Just finished pulling the RX8 and sc4x out, Savox out and cleaned too...I'm psyched. Getting it finally after 3 months!!!
Great thread so far...I will kit tomorrow as well....and post info I come across.
JMD51 is offline
Old 05-09-2011 | 10:01 PM
  #154
Perhaps Aussie's are using Aussie distributors, and Canada is using US Distributors *Shrug*
Keep'N It Cool is offline
Old 05-09-2011 | 10:07 PM
  #155
nsx_23's Avatar
Shipping to Australia from China (Assuming thats where the kit is made) is probably quicker than to the US.
nsx_23 is offline
Old 05-09-2011 | 10:18 PM
  #156
mca.'s Avatar
Backorded from Tower on the 2nd Feb or something
Shipped from Tower on Friday (sat our time),
Arrived here at lunch time tuesday (monday your time).
I claim the first SC10 in AU!? Another local Aussie is also getting his today also as far as i know.
Tower & UPS pulled Through foe me
Here is the UPS Path it took to get here http://wwwapps.ups.com/tracking/trac...02200471530886
Justin! here mate!
mca. is offline
Old 05-09-2011 | 10:21 PM
  #157
Originally Posted by maddfish
Well, I got mine today from the big brown truck. Started sorting everything out. Then building. Pulled the diffs apart to check the fluid level as it had been mentioned of low levels of fluid. Mine was low too. Everything was smooth as could be until I got to the outer rear hinge pins. One has threads and the other is smooth as silk. (no threads cut) just wanted to share for QC purposes.
Glad I could help with you catching the low diff oil" I'd bet theres alot of
guys putting them together and never bothered to take them apart to
check the diff oil to see if it's low...
They'll be alot of twitchy SC10 4x4's running around tracks everywhere
because the diffs hardly have any diff oil in them I'd bet..
Chuck 21 is offline
Old 05-09-2011 | 10:44 PM
  #158
this Canadian is not waiting...ordered from Tower April 21st...and shipped May 6th...thanks Tower
smart racer is offline
Old 05-09-2011 | 10:47 PM
  #159
My lhs should have mine in the morning, I have a mamba monster and 1410 waiting patiently for a home.
For the record to anyone thinking about the sct system, get it and don't look back, the motor is worth it alone, and the spedo will work great in a buggy or stadium truck.
Dragrcr is offline
Old 05-09-2011 | 11:21 PM
  #160
SocLiche's Avatar
This thread has shit for pictures. Does no one have cameras?
SocLiche is offline
Old 05-09-2011 | 11:30 PM
  #161
mca.'s Avatar
I will fix that give me 15 mins? then i will update during build
mca. is offline
Old 05-10-2011 | 12:06 AM
  #162
Aoh
https://picasaweb.google.com/1113101...31478/SC104x4#
so i built some sway bars for the car, since it badly needed em. used ~2.1mm piano wire for the bars. for the links i used AE 1/10 lower shock mounts on the arms and stole the bar joints from my B44 swaybar kits. the chassis mounts for the bar were made from a sheet of ABS, i cut to the right dimensions and slotted for the bar to clamp in.
i highly recommend Chris Jarosz's setup if you run on high traction clay.
Aoh is offline
Old 05-10-2011 | 12:24 AM
  #163
Cult Racing's Avatar
in order from building and almost done! Also in the last pic those are losi ten scte wheel and fit perfect to let you guys no!
Ill be running this:
Savox 1268 servo
RX8 Esc
Neu 1509 1.5d 4500kv motor
and a 3300t receiver
Cult Racing is offline
Old 05-10-2011 | 12:28 AM
  #164
Savox 1268 servo
RX8 Esc
:homo: let me drive it on Wednesday fool
i promise ill break it in half
oh wait thats right we spent the day makeing the track "10th scale friendly" ill still find a way to break something i bet
ThatOneWhiteGuy is offline
Old 05-10-2011 | 12:29 AM
  #165
haha, ill turn down the expo on remote then lol
