Like Tree3Likes
Tamiya TRF415
Old 03-20-2011 | 04:25 PM
  #20956
gsxr0311's Avatar
thanks, thats what im currently using.
gsxr0311 is offline
Old 03-20-2011 | 08:59 PM
  #20957
gsxr0311's Avatar
Originally Posted by Blueman Austria
The plastic/delrin ones with the alu sleeves work best. Very durable, and smoother than steel ones.
Greetings Blueman
would you happen to know if there is a part # for a replacement set?
also is there any other way to use a lipo battery other than the conversion kit? i thought i seen where you can just change one piece to allow the battery to fit.
gsxr0311 is offline
Old 03-23-2011 | 09:16 AM
  #20958
gsxr0311's Avatar
anybody know the tamiya part # for the replacement set of front spool cups?
what do you guys do when they are worn out, replace the entire spool?
gsxr0311 is offline
Old 03-29-2011 | 04:05 PM
  #20959
One of the Direct cup #'s is 9804268 for a MSXX
mustangswan is offline
Old 03-30-2011 | 09:08 AM
  #20960
gsxr0311's Avatar
thanks. i have those, but i looks like the blue ring that goes around the originals dont fit those. i guess that was only for the original spool and you cant get those parts. thanks
gsxr0311 is offline
Old 04-04-2011 | 09:35 PM
  #20961
BS-Racing's Avatar
Hey guys i am looking for a front ball diff for this car, but i cant find one anywhere. Do you know of anywhere i can get one?
BS-Racing is offline
Old 04-16-2011 | 06:32 PM
  #20962
waggaclint's Avatar
Hi there, just wondering how a TRF415 MSXX Chassis would compare to say a New TA05-Ver II R Chassis?
Cheers Clint...
waggaclint is offline
Old 04-16-2011 | 09:13 PM
  #20963
Cheers Clint...
TRF415 MSXX is not in the same class as TA05 ver.2-R. The former has carbon fiber double decks while the latter has carbon-reinforced platic tub. TRF415 MSXX already has all the optional parts while the TA05 ver.2-R only comes about 60% upgrades, you need to shell out at least another $200 (e.g. motor mount, and bulkheads, etc.) to make the car with full options.
If you want to race, get TRF415MSXX, if just for fun, TA05 ver.2-R will do. But don't expect them to have the same level of performance and driving precision.
eComet is offline
Old 04-16-2011 | 10:14 PM
  #20964
Blueman Austria's Avatar
Hy!
Sorry for the late reply:
Here are the sleeves. Those match with the "original" white 415 delrin cups
http://www.rcmart.com/catalog/rc-trf...th=595_744_711
This ones match with the black 3racing or also the original tamiya black 416 spool cups. But you can them use on the 415 as well. But only cup and the sleeve have to be from the same set.
http://www.rcmart.com/catalog/rc-trf...h=595_744_1230
Greetings Blueman
Blueman Austria is offline
Old 04-18-2011 | 08:16 PM
  #20965
gsxr0311's Avatar
thanks blueman.
gsxr0311 is offline
Old 05-06-2011 | 12:32 AM
  #20966
piper48
Guest
Posts: n/a
Default center one way
I recently was given some center one way pulleys from a 415 but I've never used one before. So my question is why use them? When to use them? How to use them ( with a spool, standard diff, front one way). Thanks in advance.
Old 05-08-2011 | 04:19 PM
  #20967
Phazewun's Avatar
So now with the 417 out anyone doing some cross kit mods ?
Phazewun is offline
Old 05-09-2011 | 12:07 AM
  #20968
You can use many things form the 416/416.
The whole suspension, rear balldiffs, specR Gear diff, The only thing you have to mention if the costs for the "upgrades" are it worth for you.
Greetings Blueman
Old 06-28-2011 | 12:09 PM
  #20969
Hi All
I have recently acquired a TRF415msx
Its in great shape and has the Lipo mod already done to it.
I want to update the pulleys though, so am after the MRE direct centre pulley assembly.. anyone know anywhere in the uk that might sell it?
Qatmix is offline
Old 09-18-2011 | 08:31 PM
  #20970
Burlap's Avatar
Dug out my 415 that I used to run competitively for a few years last week, to have a run at the local club. Other than the low punch lipo pack I have, it still handled very nicely. The chassis has had a fair amount of upgrades done to it over the years.
Original purchased as a 415MSX in 2006 I have since upgraded to MSX MRE setup with the better steering setup, RC Square aluminium front uprights, Evo V short arms front and rear (so much stronger than the long light arms that the MSX came with), and a lipo battery tray.
I have ordered the RC Square TB03/TRF 416 front and rear aluminium uprights for it, move to the 1050 bearings instead of the crappy small 950s that the 415 used. Hopefully get the uprights and bearings in by the end of the week and give the old thing a full strip down and rebuild.
Burlap is offline
