Like Tree1Likes
B44.1 Thread
Old 03-13-2011 | 10:12 PM
  #241
joecool's Avatar
Hey guys, I just bought a new B44 and built it 100% accurate to the manual. I took it to the track and popped the rear drive shafts out 2 times in 5 minutes of driving. I double checked the shims the on the hub, and pulled the shocks apart to check if I forgot the limiter. everything checks out. What else can I do?
joecool is offline
Old 03-13-2011 | 11:58 PM
  #242
spiro's Avatar
More than one limiter would do the trick. I've used two on my B44 this winter. (Rear shocks only. One at the front.) No popping shafts for me.
spiro is offline
Old 03-14-2011 | 03:36 AM
  #243
rednck21's Avatar
Do you guys think 23/81 is going to be too much gear for a fantom 13.5 on a tight indoor track? It's the smallest pinion I had!
rednck21 is offline
Old 03-14-2011 | 01:31 PM
  #244
should be okay... hotter motors need lower gearing and an 8.5 will run a 22/81 pretty easy. 23/81 is 8.83:1 final drive ratio, this should be reasonable for a short track. Be sure to monitor ESC and motor Temp during practice.
Banshee8530 is offline
Old 03-20-2011 | 12:15 PM
  #245
rednck21's Avatar
anyone notice the huge bump steer spacer on maifields 44.1 at the cactus classic? almost looks like the knuckle is flipped over...
rednck21 is offline
Old 03-20-2011 | 01:14 PM
  #246
Mikey Hudson's Avatar
He got rid of the steering rack and is running steering links directly on the bellcranks much like the rc8b
Mikey Hudson is offline
Old 03-20-2011 | 05:15 PM
  #247
joecool's Avatar
Check out the homepage of http://rcinsider.com/ and you can see a nice shot of Ryan Maifield's B44.1 steering linkage.
Anyone have a good picture of Ryan's car without the body on? or Cavaleri's? I want to see if they have weights anywhere somethingn special the factory team kit doesn't have.
joecool is offline
Old 03-20-2011 | 07:03 PM
  #248
Jmuck69's Avatar
http://www.redrc.net/wp-content/uplo...lieriB44-3.jpg
1/2 oz next to side body mount.
Jmuck69 is offline
Old 03-20-2011 | 07:12 PM
  #249
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
The spacers look like FT blue aluminum shock bushings.
SpraydbySprague is offline
Old 03-20-2011 | 07:52 PM
  #250
I just got a B44 in trade and tried to run it on carpet off road course, it pushes in the corner really bad.. what can I do to help that?
leaderbeanjr is offline
Old 03-20-2011 | 08:16 PM
  #251
LowBlueRanger's Avatar
I just ordered a kit and expect it later this week. I have yet to pick out a brushless system for it. I'm 100% new to 10th scale 4wd, but have ran a little of everything in the past. I'm gonna be racing this on an outdoor track thats a little tight. I was thinking on a 7.5 or 8.5, but unsure on brand. I didnt want to get the ultilmate-best, but something descent and mainly dependable. I'm also un sure on a steering servo, and dont want to spend a lot on one. Maybe a trusty hitec 625?
So if you were in my shoes, what would you power this thing with?
LowBlueRanger is offline
Old 03-20-2011 | 10:14 PM
  #252
Anyone notice that their motor runs hotter with the same gearing bc of the chassis and no cut out for the motor?
Ostach24 is offline
Old 03-20-2011 | 10:23 PM
  #253
Honestly if it's tight you won't need a ton of motor. With a mod motor of that size you can go just about anything, it wont matter what the esc can do. The motor will give you all you can handle at that speed.
Ostach24 is offline
Old 03-20-2011 | 11:53 PM
  #254
FantomLeopard's Avatar
Am I not getting something or is Maifield using Pro-Line tires and not Jconcepts?? Those rear tires look like Suburbs to me...
FantomLeopard is offline
Old 03-21-2011 | 03:50 AM
  #255
Guest
http://rcinsider.com/wp-content/uplo...3/103_2813.jpg
I am pretty sure I see a part of "JConcepts" text on those tires.
rctechuser5108581 is offline
