Houstons Engine Service H.E.S.
#4143
Monty, I know I've read it in one of the threads but I cant remember which one, I have CRS..can't remember sh...tuff,what plug should I be using on the FMS for cool/cold weather,say 50's to 70's ? thanks,the FMS is running strong,over 2 gal now.
#4144
#4145
Not Monty but i use the OD97T without fail...
#4149
What a great year Monty. Your motors put me in some great racing.
Most recently
Rcpro International Finals this past week
1rst Series Int Buggy Champion.
2nd Series Int Truggy
RCPro Texas State Series
1rst State Series Int Buggy
2nd State Series Int Truggy
On to dominate open next year.
Thanks for all your help Monty. Your the greatestest.
Most recently
#4150
Most recently
Most recently
Thanks for your continued support and let me know if you need anything
#4151
I sent you a PM saturday and haven't heard back from ya. I'm sure you've just been busy but was really wanting your advice if you can find time.
Really not meaning to be pushy at all I just trust your opinion when it comes to engines.
Thanks,
Rich
#4152
houston,
there seems to be a notch at tdc with the head off and no compression on my engine. is this bad news? basically the piston reaches tdc and then i can move the crank about 15 degrees in any direction and the piston will stay stuck in the same spot. the engine is plenty broken in. but then with the head back on there is plenty of compression so you cannot feel the notch. does this make sense?
#4153
houston,
if you are worried about it i know where you can get a rod replaced
#4155
yes it makes sense and even a new engine has "some" rod slop at tdc , i usually check that at the start of the compression stroke for preliminary then take apart and measure everything . how much fuel through engine? sucked dirt? so many questions
22Likes
